Details: Engine runs ok, but at around 2000rpm a got a intermittent clunking sound, different from the valve lifter sound.
Sound kinda like a diesel, and i dont hear it quite as much at any other rpm. Its noisiest when the engine is off load
What do you guys think : is my crank bearing on the go or im i too paranoid
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
I doubt the water pump would make such a deep clunking noise, but thanks for the cue
Crank on the pulley to be safe. Could be detonation?
I would be awfully surprised to see detonation at 200rpm without any load on the engine. I rebuilt the engine(except bottom end) last year, so i don't think there is any carbon built up in the cylinders. I'll keep looking.........
My guess, wrist pin loose or crank bearing
Check the crankshaft pulley nut. I had a similar noise, it got worse and worse until it almost fell off.. I had to tighten it with a huge extension and the car in 5th gear .
If you have an auto you may have to take the starter out and jam the flywheel to tighten the bolt.
-- 95 Impreza wagon@120k miles
-- Previously '90 legacy wagon @160k
Beware of the furious 1.8L
