ss is 140 capeable. 70-136 and still pulling, vid
ok this vid is better than the last one. you download it form the same place. its a little bigger but its alot less shaky because i use a tripod this time.
i ran out of lane choises and my exit was comming up. if i didnt exit there would have been a huge sweeper that i wouldnt be comfortable taking at that speed anyway.
it took about a 1.2 miles to get up to the end speed at 10 psi.
http://rapidshare.de/files/3245119/CIMG1102.AVI.html
select free from choices wait and download
-jason
i think we already went over that but.... its because my headlights are pointed down from a wreck and they wont adjust enough to point remotely stright
so with the brights on i get about half the regular amout of light id usualy get with the headlights normal with the regular lights i get about none in the light department which is bad.
-jason
right, sure, that may be the problem however take notice of this:
High beams are a wide angle design, even though they're not aimed as high as they would be if the car hadn't been wrecked, they're still aiming WIDE enough to blind everyone you come across.
#82 M4 TRSCCA Rallycross
the vid to download or me to get up to speed??
btw did anyone else notice that the speedometer doesnt move when the car stars reving higher then all of a sudden it moves real quick like
-jason
http://rapidshare.de/files/3278533/newvid.MPG.html
14psi until intercooler piping came off @ 55mph, hit 60 tho. WHile i was fixing the pipe a girl in a legacy wagon came along and stopped to see if i needed help. Crappy camera and hard to tape with left hand.
///M
'93 Legacy SS - part out
I like them way better than the green ones the car came with. They also look a lot better in person and they match my boost gauge and the theme on my cd player. I'll get a better video sometime. The interior dash lights were at full if that tells you how crappy the camera is, the needle should have been really visible.
///M
