Installing a muffler
Ok so Im about to bite the bullet and try to install the glasspack by myself
Once I saw off the old muffler, there's no turning back. If for whatever reason I screw up the install, is it gonna be ok for me to drive the car to a shop to get it done properly with the exhaust ending ~16" under the car?
The main issue is that there's a lot of heat coming out that pipe, and it has the potential to eventually scorch or melt any polymers in its path, like the ones forming your bumper cover. I guess in principle it could even cause fire. But one short trip shouldn't be a big deal.
I would think 45 minutes would be okay. Maybe stop partway through and take a break to let things cool off if you're worried.
They make these devices called tailpipe cutters that you can buy for like 20 or 30 bucks. It's like a chain with cutting wheels in between the links. So you put some oil on it, slip it around the pipe, and turn it back and forth while tightening it.
Or you could just use a hacksaw.
I don't know. But if you're wondering, a tailpipe cutter isn't really made for a specific size pipe.
This is probably something I don't need to say to someone who's used to living out in the middle of nowhere, but I'd call ahead to make sure they have one.
No Im wondering just to make sure I have the right sized mufflers
I actually have two, a 2" and a 2.5"
The exterior circumference of the backaxle (thats the right term for the exhaust pipe just before the muffler, yes?) is 7.25", which makes it about a 3" diameter on the outside.
That'd mean the pipe has pretty thick walls if its a 2.25 interior
But, if its 2.5" already, why do people spend so much money on getting a 2.5" installed??
7.25" divided by pi is close to 2.30.
I don't think it's 2.5". 2.25" is probably right, but you should search for a post from someone who knows.
But even keeping the same diameter could be helpful if you switch to mandrel bends from the stock crush bends.
People usually call the portion of the exhaust all the way from the last flange to the muffler tips the "axleback."
Gah I did my math wrong... I cant believe that. lolvrg3 wrote:7.25" divided by pi is close to 2.30.
Thanks for your help, I'll give them a call and see what happens
I took it for a spin around the block and when I got back I could smell burning rubber, the cords were still ok, but I replaced the ones near the tip with some planters wire that I rolled 4-fold. Good job too, because after a 10 minute drive the one near the intake end melted.
I picked up another muffler clamp while I was out, Im still not sure how Im gonna do this tho
The Scooby
well whats intresting about glasspacks, they creat scavenging which will help pull out the exhaust from the engine, so ya i bet you would feel a difference.
it actually will out flow strait pipe.
also please get up soem sound clips, my car is like yours twin, and ive been thinking of putting on a glasspack since i dont want a TBE.
1986 GL wagon
EJ'ed and Lifted
1986 GL wagon
EJ'ed and Lifted
BAC5.2
I think you may be mistaken.The Scooby wrote:well whats intresting about glasspacks, they creat scavenging which will help pull out the exhaust from the engine, so ya i bet you would feel a difference.
The muffler will have no scavenging effect on a turbo car. Sorry.
Do you have proof that a glasspack will outflow a straight pipe? I don't see how that is possible.
The Scooby
when i was still going to school we got to use a flow bench.
we put on a peice of 2.5inch strait pipe that we used for header extentions on the T-buckets, and ran it, then otehr muffler and saw what mufflers where restrictive and what ones wheren't too bad. we also ran a thrush cherry bomb, it actually out flowed the 18inch peice of pipe, the cherry bomb was also 18inches long.
1986 GL wagon
EJ'ed and Lifted
1986 GL wagon
EJ'ed and Lifted
What was the ID of the 2.5 in pipe and the ID of the glass pack? Were they the same?
