Where is the starter relay?
MY92
Post by MY92 »
When I turn my car from on to start, it doesn't click at all.
Battery is fine.
Starter cranks if I jumper it from the battery.
Starter solenoid connect see's no voltage if I plug it into my multimeter and try on-start with the car.
John
http://www.cardomain.com/ride/560635
I'm going to assume you have a MT.
The starter interlock relay is under the dash. It has a blue connector like this one in the pic
http://www.surrealmirage.com/subaru/ima ... rness2.jpg
subawhatsubawho
Post by subawhatsubawho »
If you have an automatice tranny try shifting it thru the gears and then put back to park. Every now and then my car won't start and I will have to do this.
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
