Full boost half throttle
Splinter
Post by Splinter »
Ive got my MBC connected up to where the stock solenoid was connected (with new hoses), and Im boosting up to 13PSI in 4th (4EAT) when Im cruising with the throttle half down.
It also has a tendancy to boost up to 12 or 13 and drop down to 10 when Im at full throttle.
That is, it holds boost BETTER at half throttle than full throttle.
Vac leak maybe??
dscoobydoo
Post by dscoobydoo »
Maybe, but my leagcy pulls better about 3/4 throttle. If I push it full throttle, it's like it does not push as hard. You can tell the difference.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
renaud
Post by renaud »
me the 1/3 trottle pedal is where i got the more power boost... lol
Happy to see that I'm not the only one to have that shit on my car
kidatari
Post by kidatari »
I had that problem really bad with one of my previous Legacy SS' (4EAT). It was causing high EGTs, which is no good at all. But this was all under factory boost control, which makes me wonder if the boost solenoid took a crap, or the wastegate was acting 'iffy.
Usually it's referred to as PTFB- Part Throttle Full Boost. Basically your turbo is trying to push 12-14psi through a partially closed throttle butterfly.
Of course, I never figured out how to fix the problem before the car got drifted into a K-wall at Thunderhill, so I don't really have a fix.
I plan on expiramenting with some aftermarket boost control on my 91 5MT SS when I get back to the 'states.
[size=75]91 Perl White 5MT Legacy Sport Sedan[/size]
NICO
Post by NICO »
wow i had that problem a long time ago.
you need to open up the exhuste get headers and a bigger turbo, and get a electronic boost controller.
best boost controller in the world i say turbosmart e-boost.
rallysam
Post by rallysam »
This sounds weird. Could you show us a picture of how you have it hooked up?
'00 Impr RS - sold
Splinter
Post by Splinter »
Digicam is shot...
Ive got a vacuum hose from the compressor nipple to the inlet on the MBC, and the outlet of the MBC hosed to the waste gate actuator.
rallysam
Post by rallysam »
Well, that sounds like you've got it right. Most people get PTFB because they hook up their MBC to the intake manifold instead of the compressor outlet, but luckily you knew better.
As you know, it's a pretty simple control system, not that much can go wrong with it.
All I can think of is:
* One of those two hoses is leaking. Inspect them closely, and clamp all connections with some quality clamps.
* Your MBC isn't working right, is clogged, or you hooked it up backwards.
One more important question, how do you have your boost gauge set up? Where is it plumbed to?
'00 Impr RS - sold
Splinter
Post by Splinter »
boost gauge is hooked up to the intake manifold, between the manifold and the canister purge hose
I know its accurate because I was hitting fuel cut right where I was supposed to when I was tuning the MBC
The MBC isnt hooked up backwards, when its backwards the boost is totally uncontrolled.
Theres an excellent chance it isnt working properly though, I'll try and find a different spring to use.
rallysam
Post by rallysam »
Splinter wrote:MBC it hooked up to the intake manifold, between the manifold and the canister purge hose
You mean the boost gauge is hooked up to the intake manifold, right? The MBC isn't - you said it's hooked up to the compressor outlet.
This behavior makes no sense to me.
One thing that might shed light, is you could temporarily connect the boost gauge to the compressor outlet. To do that, you could tee off one of the lines for the boost controller. That would tell you more about what the turbo and MBC are doing. Right now, you're trying to see what the turbo is doing, but your view is blocked and confused by all this stuff between the gauge and the turbo that introduce their own pressure variations (the throttle plate, the intake restrictions, and intercooler).
'00 Impr RS - sold
Splinter
Post by Splinter »
rallysam wrote:You mean the boost gauge is hooked up to the intake manifold, right? The MBC isn't - you said it's hooked up to the compressor outlet.
Yea sorry
rallysam wrote:One thing that might shed light, is you could temporarily connect the boost gauge to the compressor outlet. To do that, you could tee off one of the lines for the boost controller.
I'll try that.
Splinter
Post by Splinter »
Fixed the problem by punching a tiny hole in the hose from the MBC to the wastegate
legacy92ej22t
Post by legacy92ej22t »
That doesn't sound good. :? You fixed it by creating a leak?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
sammydafish
Post by sammydafish »
legacy92ej22t wrote:That doesn't sound good. :? You fixed it by creating a leak?
not a leak, a vent. all MBCs need this. It only needs to be a very small hole in order to relieve pressure on the actualtor side of the valve. If not then the pressure in the line will hold the valve closed requiring more pressure to open the valve than the spring is set to. Usualy this causes crazy boost spikes, not the behavior seen in this post. Seeing more boost at part throttle than you do at WOT means one of two things to me, bad tunning or to small a compressor (can't flow the air required at WOT).
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
Splinter
Post by Splinter »
Yea, I think what was happening was that high pressure was trapping the wastegate open
legacy92ej22t
I know that MBC's need a bleeder hole but the MBC should already have the hole on it. Why would you need to put a hole in the vacuum line then? Wouldn't that make two holes?
Still doesn't sound right to me.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Splinter
Post by Splinter »
Homebuilt MBC
BAC5.2
Post by BAC5.2 »
Unless the MBC used was a pile and didn't have a bleed hole in it.
rallysam
Post by rallysam »
Splinter wrote:Homebuilt MBC
Ok, that explains it
'00 Impr RS - sold
I wouldn't rely on a pinhole in a rubber hose. Just drill a little hole in the MBC. If you don't have the means, ask a friendly jeweler.
