Ralliktek and I got our ej22t rebuilds started today....
douglas vincent
Post by douglas vincent »
By buying the rod and main bearings and head gaskets. He also picked up rings, I already have em.
Nice thing is that Kelley has a nice connection with the discount import parts store that I frequent.
$ 56 for turbo rings
$45 main bearings
$30 rod bearings
and
$70 for head gasket set. And this isnt any old head gasket. I havent seen this style yet (not that I have seen a HUGE amount) but they are 100% metal. There is a metal core, and instead of a composite material on the outside, they are a thin sheet metal with imprinted ridges around the important areas that are crush fit when installed.
So next step is for Kelley to pull his motor, and then we do a dual bearing rebuild and the he and I go in different directions for the head work.
Is this metal headgasket thickness the same as the OEM composite one?
206er
Post by 206er »
Ive got the metal headgaskets in my motor. they are very cool and supposed to be much stronger than the normal type.
jnorion
Post by jnorion »
Nice. I'd like to check out your car at some point... I'm very curious about it.
~Joel
douglas vincent
Josh, I think so. I havent had a chance to mic them yet, I may go back to the shop tonight...
Post by 555BCTurbo »
Hey Portland guys, we should have a mini-meet sometime soon...I especially want to see the Red Devil Doug!
Maybe hit up Sykart and some lunch or something one day!
Kelly
Post by Kelly »
I'll be seeing you this weekend Nick :lol:
Hey Doug!
Come up to Doo Wops with us this weekend.
Sweet!!!!
I am staying at the Nordic Inn...so hit me up
my ph# is 503-932-9622
jnorion
Post by jnorion »
555BCTurbo wrote:Hey Portland guys, we should have a mini-meet sometime soon...I especially want to see the Red Devil Doug!
Sounds like a good idea. When?
~Joel
douglas vincent
I am going to try. Don't know if the wife will let me.
Hows about the 25th of March? It's a Saturday, btw...
If we have enough interest I will get on figuring this out!:D
Legacy777 wrote:Is this metal headgasket thickness the same as the OEM composite one?
Anybody have an answer on this?
douglas vincent
yes
Thanks Doug!
