So help me diagnose my engine sputtering
Ok, so now i've soldered the internal wire together and used some heat shring tubing to seal it up. Then I took that external wire and as best I could, I brought them together and put some solder on them to keep them together and put some heat shrink tubing around that. I then wrapped all the wires back up and connected everything back as it should be. Would anything done to the knock sensor wire prevent my car from starting up? Now it won't start. It won't even act like it will start up. It turns and turns, but it never catches. Almost like the fuel pump isn't on. The only thing I touched was the crank, cam, and knock sensors, and the knock being the primary one. Could any kind of a screw up on the soldering job cause a problem like this?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
Nothing with the knock sensor can keep it from starting. I suspect the cam or crank sensor. If you pull the trouble codes you can find out which one -- if one of them gives a signal and the other doesn't, the ECU stores a trouble code for the one with the missing signal.
That was it Vikash, thanks. The cam grounding wire had snapped from my last job. I hate brittle wires.
Starts up like a beauty now.
2014 Volvo S60 T5
2014 Volvo S60 T5
Well it ran like a charm on the way to work, but after getting off the freeway I pushed it again and this time when the boost reached about 10 or so the car acted real funny. Not like timing was thrown back more like like it just hit a wall and there was some sputtering, but not the kind of sputtering where it feels like your engine is trying to stay running. If I eased onto the boost at that point it was fine. It just didn't like the sudden punch under a load. Maybe I need to start looking at my MAF now, or maybe I need to go back and look at all my wiring jobs I just did on the cam and crank sensors. I'm not sure what this could be, but at least my sputtering at low speed, the "leave me dead in the water" kind of sputtering, is gone.
2014 Volvo S60 T5
2014 Volvo S60 T5
All good points. The very first time my car acted like this it was because I needed to regap my plugs. So I'm hoping it is ignition, plug, plug wire related. Now it is just time troubleshooting. The wires are only a couple years old, so I think they are fine.
Splinter: It was blowing off your spark plug wire? Crazy.
-Ryan
-Ryan
2014 Volvo S60 T5
2014 Volvo S60 T5
Well back to the drawing board. First I'll check my wiring, then start playing with the MAF and the other fuel delivery/spark delivery components.
The sputter that leaves me limping came back just a bit ago. Almost didn't make it across the intersection before it was red. Once I did the car picked up and drove normal. GRRRR....
An odd question, but can a failing turbo cause this sort of reaction? Just something else to watch out for.
2014 Volvo S60 T5
2014 Volvo S60 T5
Also, how would a gas tank leak affect things? I just found out I have one. Only when the car is full an parked with the nose significantly higher on a hill than the tail. I'm going to have to figure out where that leak is coming from.
I'd figure if it was a fuel pressure thing due to a leaky tank, I'd notice it all the time, not just randomly.
2014 Volvo S60 T5
2014 Volvo S60 T5
Leaky gas tank just will manifest as poor mileage and a smelly parked car. Most times gas tank leaks with our cars is where the filler neck mates to the tank, although I did have to patch up a hole in the rear with some JB weld. That stuff is the shizzle.
Have you ever replaced your stock fuel pump? I highly recommend a Walbro 255lph with the WRX install kit on general principle.
-Chris
91SS 4EAT stock, 200k mi
I have the walbro pump already. I put that in before I put in the vf8.
Ok, so I don't need to worry about the tank or a turbo issue as I diagnose this renewal of sputtering. That's good.
2014 Volvo S60 T5
2014 Volvo S60 T5
So I MAY have solved it. We'll see. I swaped out a coil back to another diamond coil, and while I was fixing my oil leak from the turbo I noticed that the signal wire on my 02 sensor was melting, or getting rubbed away. Half of the shielding around the signal wire was gone and the wire itself was exposed. I replaced it with a NA 3 wire sensor (I had a 4 wire one). All today the car has run pretty stable. No sputtering. It hasn't even sputtered when I'm pushing it at full boost (which it would do often before, and I felt it was related to the sputtering I was feeling at random times). So if this fixes it I'm going to guess it was the 02 sensor giving the ecu some funky readings and messing with the fuel delivery of the car. We'll see. Only time will tell now.
-Ryan
-Ryan
2014 Volvo S60 T5
2014 Volvo S60 T5
