Auto seatbelts not working
Does anyone know where the auto seatbelt control module is, nobody at work seems to be able to remember the early 90s, and all they can tell me is that its in the back somewhere? Also anyone know of any common problems with the auto sholder belts? Its getting really annoying to have to latch the sholder belt in every time i get in the car.
http://www.surrealmirage.com/subaru/fil ... tion06.jpg
You may want to look at these to diagnose the problem.
http://www.main.experiencetherave.com:8 ... _diag1.jpg
http://www.main.experiencetherave.com:8 ... _diag2.jpg
http://www.main.experiencetherave.com:8 ... tdiag1.jpg
http://www.main.experiencetherave.com:8 ... tdiag2.jpg
http://www.main.experiencetherave.com:8 ... tdiag3.jpg
IronMonkeyL255
If you end up needing a new module, I have one kicking around that I don't need.
Rio Red '91 Legacy SS
