Gap under headlights
I was washing my car today when I actually stopped to look at it closely. While I was washing the front I realized that there is about a 3/4" gap between the bottom of my headlights and the top of my bumper. My headlights are perfectly aimed and the only thing I can think of that could have an affect would be the fact that my car got backed into by a car going approximately 15 mph (my passenger side front quarter panel got buckled out a little bit). Is the fender bender responsible for the gap? And outside of replacing the bumper, it the problem easily fixable?
91 Mica Ruby Pearl L Sedan[color=#800000][/color]
Manarius
My car has a similar gap..I don't think it's 3/4" though. It's probably closer to 1/4".
IronMonkeyL255
LaureltheQueen
- Spelling Nazi
My bumper is slightly tilted down from impacting huge chunks of snow kicked off by plows on the highway ... on purpose. I definitely had a larger gap before I did the headlight swap. If the sides of your bumper aren't real tight to the fender then it's not where it should be.
here's another thing: the bracket/clip on the bottom of my grill is broken in half so a screw no longer holds my grill onto my car. the grill is being held on to the engine area by two zip ties
i think this might have happened when i got backed into. maybe the bumper got pushed down and broke the clip. it's nothing too major, right? nothing's rusting or falling off so i think it'll be okay.
The grille should have 7 clips that hold it in - 4 on top, 3 on the bottom. There are a couple of ways to remove them, but they can only be reused so many times and they do suffer from environmental exposure over time. Putting a zip tie through the holes in the grille and body that the clips should go through would be fine. You don't need all 7 either.
yeah, all the clips have been broken. understandable, since my car is 15 years old! i only have two zip ties on the top holding the grill on, so it doesn't look too bad. plus, they're black, so they blend in with the grill nicely
. i plan on getting a new grill anyway, so the problem will be solved. i think replacing the bumper would be unnecessary and not worthwhile. it gives my car character
Manarius
My car turns 15 in December, and I have 6/7 clips (my dad broke one when he was taking off the grille)Suzie-Q wrote:yeah, all the clips have been broken. understandable, since my car is 15 years old!
IronMonkeyL255
You shouldn't have to replace the bumper if it's pointed down as the support under it is what's bent. Removing the bumper cover and bending it back up (with a jack under it?) would likely fix it. At some point I'll get around to it myself.
TheSubaruJunkie
The Front bumper on my Wagon is sagging, looks like it had been backed into or something. No damage to the bumper, but there is a noticeable gap between the headlights and the top of the bumper.
I really want to repair this as it makes my car look like crap.
Does this mean I need to remove the bumper and bend something back in place? Or are there bolts that hold the bumper and I can losen and just adjust it?
-Brian
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
1986 Toyota 4Runner
ur car looks real good, i like white, but then again i like silver, but then again i need to align my doors, get two new front fenders,a bumper, a hoob, and new corner lights , a new rear bumper, the rear trunch lid needs to be sanded, and repainted, and my doors need some bondo, and some sanding, so that i guess could cause the car to looks a little crappyTheSubaruJunkie wrote:The Front bumper on my Wagon is sagging, looks like it had been backed into or something. No damage to the bumper, but there is a noticeable gap between the headlights and the top of the bumper.
-Brian
TheSubaruJunkie
ericS2the6
TheSubaruJunkie
