High Pitched Sound
1990 Legacy L Owner
High Pitched Sound
Post by 1990 Legacy L Owner »
I've acquired a high pitched whistle in my engine somewhere. It does it from the moment I start my car until it gets warm. I've been researching the problem quite a bit on google and here.
Many members on this board have a had a high pitched chirp, squeel and whurr, but none were like mine and none were a help.
It goes up in pitch and it get a bit louder when I accelerate.
I don't think it's the AC compressor because it doesn't change with the on or off of my heater.
I don't think it's my steering rack because it doesn't change when I turn the wheel.
I read somewhere on the web that Subaru's will put out a high pitched sound when the tranny filter gets clogged, is that true?
So, is it my tranny needing a look at?
Any other ideas you can come up with?
The last time somebody posted a high pitched sound, I believe, was in 2005. Somebody has to have experienced it since then.
Thanks in advance!
Chris
Carbix
Post by Carbix »
Its called a TURBO. :twisted:
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
Loose belt?
1990 Legacy L Owner
Don't have turbo and my belts are tight.
Chris
Subaru for Life
Post by Subaru for Life »
Water pump, may be? Could also be any of the pulleys.
Good luck,
Subaru_for_Life
idler pulley probably.
mattyg41383
Post by mattyg41383 »
my brothers '98 GT had a high pitched squeal on acceleration, which changed pitch with RPM. after a pile of parts including belts and a new cold air intake; a new water pump solved it.
so x2 - water pump
-Matt
1993 Legacy SS - auto
1997 Impreza coupe
1986 XT - 14.5s @ 95mph
1990 Legacy wagon "the Red Dragon" -sold (300K miles and it lives on)
1990 Legacy L Owner
Well, I thought it might be my air cleaner because one screw was missing. I thought maybe the air cleaner not being tight on the one corner was making the air whistle. I replaced all screws and washers, didn't help. It did help acceleration a bit, though.
The whistle doesn't effect performance, it's just annoying.
Another problem is that after a rain, I try to start my car and it'll start, but it runs really rough, doesn't itle and a touch of the gas petal kills it. At the same time, when I start it, I hear water moving around. Is that just the coolant cycling? Maybe the oil cycling through? The check engine light is coming on and I need to learn how to check the codes. I'm going to search around to see if I can find out how. I don't even know where to look for the flashing light I've read about somewhere here.
Thanks a lot for the suggestions. I'm just gonna have to find it through trial and error.
Chris
stipro
Post by stipro »
The flashing light will be the check engine light its self. Once the connectors are together.
Check this out for the procedure and codes:
http://legacycentral.org/library/literature/codes.htm
Tone-us
Post by Tone-us »
Running rough after rain = Knock Sensor under the Intake Manifold. Check to see if it has a cracked top... if so, replace.
