FS: AT related stuff
I have some 4EAT stuff that needs a new home since I did a 5MT swap.
4EAT - Has some shudder, torque bind type stuff going wrong. Maybe you need it for parts? The only thing missing is a wiring harness I cut off. I'm not sure which year it is, the previous owner put it in to replace the original 4EAT. FREE and it comes with crossmember and mount
driveshaft - the u-joint on the trans end is busted/frozen FREE
shifter assembly - the light bulb is burned out, other than that it works, $15
shift lock - it's a shift lock unit and it works, $5
center console - excellent condition, has all clips $15
AT starter - worked every time $50
2 TCUs - The one on the left is from a 1990 wagon, the other is from a '94 turbo wagon, they both worked identically $20 each
brake pedal - $25
I also have the flexplate (both parts), the bracket for the pitch stopper, shift cable, a couple small wiring brakets, and AT fluid filter.
Prices are negotiable, or got something to trade?
Parts located in Kirkland, WA.
Local pick-up only on the big stuff, buyer pays shipping on small stuff.
head2wind
Post by head2wind »
Hey, are you going to be north to B'ham anytime soon? I could use that transmission.... or I can come get it also.
94 Silver Turbo Wagon 5MT/Walbro255/SS header/STi Gn Mounts/01 RS wheels
I go back and forth every once in a while. Might be a month or so before I could bring it to you.
You could get it faster by picking it up. :-D
head2wind
Post by head2wind »
is this a turbo trans or non turbo?
It's a non turbo 4.111, with probably about 80K miles total based on what the P.O. told me. It worked the same with either NA or turbo TCU. I think the main difference between them is the final drive ratio, and the turbo has one more driven/drive plate combo in the clutches.
A few months before I removed the trans duty solenoid B was replaced by a subie-only mechanic. He didn't replace the clutch packs, so it does shudder while driving. It functions fine, it's just not smooth.
Anyone need a part out of the 4EAT?
It and the driveshaft are going to the scrap heap in a few days.
