Hi!
If you want an even higher initial peak boost value, simply T into the wastegate line a small sealed volume, such as a small aerosol can or the pictured camping water container. This will allow boost to flare a bit, as the can needs to fill with pressurised air before the wastegate starts to move. This can be a surprisingly effective modification - on one Charade Turbo, fitting just the over-boost can was enough to give wheelspin on every full throttle first-second gear change!
<http://www.autospeed.com/image.html?A=0 ... =%2Fimages> Click for larger image
cheers
¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,¤º°`°º¤ø,¸¸
Info: John Carlsson UK 92 Legacy 4 cam Turbo Estate
E-mail : penty@nettaxi.com
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975351988?> click here
What do people think about this?
JohnnyG
This canister is known as an accumulator in pneumatics theory. They do work, but I belive you need to calculate / play about the correct volume required in the canister for a specific turbo. I have heard about 160cc provides a reasonable delay to wastegate actuation and wastegate leakage (always an issues to some degree)
One of these accumulators in a T comibination with a restrictor valve in series with the wastegate actuator feed, is a far superior setup to a bleed valve.
John Gillon
----- Original Message -----
To: Legacy egroup <mailto:BC-BFLegacyWorks@egroups.com>
Sent: Tuesday, November 28, 2000 7:58 AM
Subject: [BC-BFLegacyWorks] What do people think about this?
Hi!
cheers
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975379730?> click here
John Gillon
Hi!
cheers
eGroups Sponsor
penty
Can you please go into that again
what is a T comibination with a restrictor valve in series with the wastegate actuator feed????
and why would this be better then a bleed valve?
john<---------nice but dim
cheers
To: BC-BFLegacyWorks@egroups.com
Sent: Tuesday, November 28, 2000 2:45 AM
Subject: Re: [BC-BFLegacyWorks] What do people think about this?
John Gillon
Hi!
cheers
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975413326?> click here
cheers
John Gillon
Hi!
cheers
eGroups Sponsor
