14s on turbo legacy? big no no?
dirtyhandssubaru555
Post by dirtyhandssubaru555 »
i was just told that i shouldn't have 14 inch rims on my turbo leg, do to the fact that they don't clear the calipers, i am getting some rubing sounds but only under hard cornering. the car came with 14s when i bought it and i haven't drove it much. so should i change to stock 15s?
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
Saskatoon Subaru
Post by Saskatoon Subaru »
why would you want smaller rims? most people wanna go biggger
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Yes. They rub when you turn due to flexing of the wheel. Regardless, the car will handle better with some larger alloys (within reason of course). I'm surprised they don't rub a little more than that.
jamal
Vendor
Vendor
Post by jamal »
I'm surprised you can even bolt them to the hub, although it really depends on the wheel. There are 15" rally wheels that will clear WRX 2 or 4-pot brakes.
dirtyhandssubaru555
i don't want 14s but that is what came on the car, i would lvoe some 16s
86 gl hatchback rip
87 gl10 rip
jamal
Vendor
Vendor
Post by jamal »
pick up a set of WRX wheels and tires locally. That will solve everything. 16s with decent tires go from $200-300.
DLC
Post by DLC »
You're going to have to post pictures of this. There might be some crazy 14s that fit, but can you make absolutely sure they're 14"?
Legacy Central
BAC5.2
Post by BAC5.2 »
jamal wrote:I'm surprised you can even bolt them to the hub, although it really depends on the wheel. There are 15" rally wheels that will clear WRX 2 or 4-pot brakes.
Which ones?
BXSS
Post by BXSS »
Folks may want a small wheel for less rotational inertia, which is why I have the stock 15's on my SS although I have 2 sets of 16" (Gold STi V2s, & WRX) rims & a set of 17" rims (ROTA Actions) in the garage. I'm surprised 14's even fit, but they may be tooo small if they are rubbing on the brakes.
15" Rally wheels that fit over 4pots & WRX 2pots are enkei's, & team dynamics. The enkeis are pretty expensive @ 225-250 per 15" rim while the TDs are like 200ish / rim. Just take a look @ rallispec site & they have everything broken down there.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
jamal
Vendor
Vendor
Post by jamal »
BAC5.2 wrote:
Which ones?
Enkei ES and Speedline corse to start. There are a few more.
BAC5.2
Post by BAC5.2 »
BXSS - Which of the 15" Enkei's fit the brakes?
BXSS
Post by BXSS »
RC-G4's & ES Gravels will, check the link. Dave is very helpful & will ans any ?s, he says these will fit over 4pots & WRX 2pot brakes.
http://www.rallispec.com/prod_wheel.htm
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
dirtyhandssubaru555
might be able to get a better pic later.Image
86 gl hatchback rip
87 gl10 rip
