Hi all. I'm having a problem with my turn signals not working, no light, no blinking, yet my hazard illuminates all the proper bulbs, and flashes just fine. Any thoughts?
Thanks in advance.
'91 Legacy combo switch?
dropdfocus
Likely years of dirt & corrosion on your connections for the turnsignal stalk. It moves a switch to the appropriate metal tabs. The mechanism is located in the steering column cover by the plastic shroud.
I had the same problem with my Toyota & Nissan pickups. Pulled the switch out and cleaned the gunk out of the contacts with a Q-Tip & cleaned the metal strips the rest of the way with a pencil eraser.
Jason
