Today i was driving pretty fast in the rain... trying to push the car
a bit... after a few corners, trying to perform the swedish flick,
although unsucessfull, i noticed that my ABS light came on... I know
that its probably some water shorted out the wheel speed sensor or
something.. i restarted the car and everything back to normal..
i when the ABS light came on, i found the car to be more fun to
drive.. turn in oversteer seems easier to perform and everything just
seem more fun!! wondering if there is anyway to disable the ABS
without trying to do get water to the wheel speed sensor..
Disabling ABS
jason grahn
Disabling ABS
Ricky-
pull the fuse.
Jason
>From: "Ricky" <prostho@netscape.net>
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Subject: [BC-BFLegacyWorks] Disabling ABS
>Date: Fri, 02 Mar 2001 03:30:14 -0000
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
pull the fuse.
Jason
Mark Ward
Disabling ABS
Front left of the engine compartment in the fuse panel, marked "ABS"
happy locking up...
Mark
>From: "jason grahn" <jgrahn555@hotmail.com>
>Subject: Re: [BC-BFLegacyWorks] Disabling ABS
>Date: Fri, 02 Mar 2001 07:569 -0800
>Ricky-
>pull the fuse.
>Jason
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
happy locking up...
Mark
>Ricky-
>pull the fuse.
>Jason
Ricky
Disabling ABS
Thanks guys... i will do that again when the road is wet..hehe..
does the ABS light come on when i pull the fuse and are there any
negative effects on the braking system if i pull the fuse?
Mark Ward
Disabling ABS
Yes, it comes on till you plug the fuse in and restart the car..
Mark
>Subject: [BC-BFLegacyWorks] Re: Disabling ABS
>Date: Sat, 03 Mar 2001 05:10:10 -0000
Mark
jason grahn
Disabling ABS
Yes, your light will come on, yes there are negative effects. Your brakes
will lock up, making you slide, possibly causing a catistrophic accident.
Jason
Jason
