Running with no t-belt covers??
TheSubaruJunkie
Post by TheSubaruJunkie »
So the t-belt cover on the passenger head is fucked up. while doing my engine, I failed to remove one bolt holding the timing cover back to the head, and when i went to remove the cover, it broke. doesnt really bother me cause that piece was also warped and showed signs of rubbing on the belt and the cam pulley.
So Im wondering if I can get away with running without that piece? The center pieces and the section that covers the drivers side cam are still good.
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
asc_up
Post by asc_up »
I ran without that exact same piece for awhile, but I had the same question and decided to follow the advice of others on this board and put the piece back on/find a replacement piece.
You'll probably be ok for running around town and whatnot, but if you're going on a long trip or something then you should get one. All it takes is one rock or something to wedge its way in there...
Ej22TIM
Post by Ej22TIM »
as long as an object such as a pole or rod or something dosnt jam through your radiator, you will be fine. I ran with no timing belt cover whatsoever all summer and had no problems.....
Tim
93 Legacy SS Winestone 5mt swapped
Megan Racing Bellmouth 13psi
WRX Intercooler and Hoodscoop
JDM ej20G DOHC head swap, wiseco pistons and td04 in the making.
James614
Post by James614 »
If a rod or pole jams through your grille/bumper, A/C condenser, and radiator, I have a hard time believing that the timing belt cover will save you.....
My old Jetta didn't even have a closed timing belt like these cars do. It probably helps for the longevitity of the belt to keep it clean, but unless you sink your car in 2ft of sand or do doughnuts in pea gravel, there's really not much risk of anything getting fudged up with the entire cover missing for years that I could see.
That said, Subaru had it there for a reason, so just relax for now but still get a replacement when you can :D
New92
Post by New92 »
Ive run cars both ways, cover on stock and no cover on adjustable cams and I never noticed any difference in belt life or safety. You would really have to be doing something extreme to cause a problem there.
1992 SS 5MT
Hocrest
Post by Hocrest »
I've been running naked on my SVX for 8 months/20,000miles.
The cam wheels have acquired a light coat of rust on the areas where they don't contact the belt, I have another set that I plan to coat and replace them with when the weather is nice.
I also carry a spare belt and pre-set tensioner just in case ;-)
We've been naked on the racer and it makes it so much quicker to service anything up front. I've replaced the waterpump in less than 30 minutes :)
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
tyrone
Post by tyrone »
i have been runnin my car with out either side for the last 2 years i think ull be fine
i love my legacy
Brat4by4
Stratified
Post by Brat4by4 »
Lots of EA guys do it. Just keep an extra belt with the tools laying around so you can replace it in 15 minutes.
