Restore's Engine Restore, anyone use it?
93Leg-c
Post by 93Leg-c »
James614, you could be absolutely correct in your explanation of Restore. I just posted what was explained to me by a mechanic guy. I recall asking him if all that metal stuff or whatever it was floating around in the engine would plug up oil galleys and damage the engine and he explained it by saying that the particles were so small that it wouldn't do that but that it was also temperature-pressure sensitive in that it would fill in microscopic gaps, grooves, etc. in piston rings and bearings because of the higher temperature and load they experienced but not acculmulate or bind to metal in other areas such as oil galleys were there was no load/temperature conditions.
Now, he could have just been giving me a story. I don't know. I'm not an engineer and I didn't research it. All I know is that I did use it and it did work for me whereas other oil additives did not work. A few helped just a little bit but the cars still smoked a lot (the very worst was STP Oil Treatment--that stuff would start clumping up in the oil pan after about 1,500 miles). Restore was the last product I used because it was so expensive compared to the other oil treatments. But once I tried it, I stuck with it because it worked so well in the cars.
And for everyone reading this thread, if the information I posted is wrong, then I do apologize. I certainly don't want to spread false information of any sort. But I did post originally to answer the question at the start of the thread and to share my experience with Restore and what I was told about it.
However, I should add that I knew that once the engines started blowing oil out the tailpipe that it needed to be rebuilt and that the Restore would only be a temporary measure. But I felt that if the engines could go another 9 months or so then it would be worth it. My dad's car ended up getting totaled a few years later (yeah, it did actually go for years) and the VW engine was totally rebuilt (with a big bore kit, carb, etc. too :D )
'94 TW
James614
Post by James614 »
I have quite a bit of repressed memories regarding "liquid fix" additives, and so your mention of Restore kind of sent me off on a rant. My first paragraph was more of a "no liquid fixes work the way the manufacturer says they do" kind of instant reaction, I don't actually know how it works for sure :shock: (aka talking out of my ass, which I happen to do more than I'd like). But from what I've seen and heard, the "microscopic metal filling in scratches and scores without affecting the rest of the engine" thing is more marketing than exact science (some products blatantly lie about how they work, but I'm not gonna go that far with Restore).
Now that I've vented about how pissed off I've gotten at liquid fixes in the past, let me say that before my Jetta's rings went, the Restore did seem to be working as advertised, and I WAS pleased with the results! Until my pistons rings went, of course. But for all I know they were already close to a point of catastrophic failure well before then, and the Restore just worked well enough to hide the problem until they exceeded their mechanical limits. I strongly suspect that they failed faster and more suddenly because of the Restore, but I can't say for fact that it was the case. It could just as easily be the opposite.
But I stand by my last statement in my previous post, anyone caught using Restore (or any other liquid fix) to on a car for resale should be subject to extensive and brutal corporal punishment, followed by their death.
Post by SubaruNation »
uh... is seafoam a liquid fix it :shock: :?
James614
Post by James614 »
Seafoam is okay :-)
James614 wrote:Seafoam is okay :-)
... :-D ok good i thought i was done for!
