ok so when i got my 92 auto SS the gas tank was leaking.
i replaced it at my shop and during the replacement i changed some lines and the usual...
there is a little sort of "black thing" that sits on the passenger side under the car right at the rear edge not far from the gas tank (roll over valve maybe?) with 3 lines going to/out of it one of these lines snapped, not wanting to look into replacing the part i just bypassed it so there are still 2 lines going through it and a hole.
i do not see leaks and i do not smell gas BUT when my car has been sitting for a few minutes when i go to turn it on it takes a bit to start up, it seems like it takes a moment for the fuel to get to the engine. this was happening before i changed the tank but i assumed it was just because it wasn't holding any pressure, after the change it got worse.
my questions are, is that black thing under the car important? should i replace it, bypass it fully and get rid of it, or leave it as is?
is my starting problem associated to this part? what else could it be?
this is pretty hard to explain so if anything is unclear let me know and i will try to clarify
thanks alot
-Alex
roll over valve? starting problem
mexicanzero
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
Any chace of a picture?
The roll over valve I believe is on the driver's side in front of the fuel tank.
The passenger side has the vent lines going to the fuel separator. Maybe you saw that....without a picture....I couldn't say for sure.
mexicanzero
sorry i made a boo boo
i meant the drivers side when i said passenger side...
as for pictures i will see what i can do tomorrow on my lunch break
any ideas on what would cause my starting problem? is there some valve that is supposed to keep the fuel in the lines keeping it from going back to the tank?
the car always starts its just really annoying...
-Alex
-Alex
