Mods to 92 Legacy?
grantsubaru@yahoo.com
Mods to 92 Legacy?
I've been trying to improve performance on my 1992 Legacy L and was
wondering if anyone had any suggestions. I bought a KN filter last
week and it has helped a bit. I am thinking about looking into a
performance exhaust system and possible replacing the stock pulley
sytem with a performance set. Any suggestions or stories would be
appreciated.
Grant
Oh yeah. I bought some custom wheels for my Legacy and the offset on
the wheels is signicantly lower than stock and now whenever I hit any
bumps or dips significantly my wheel well hits the tire. Has anyone
else experienced this problem. I am either going to trade out the
rims or get lower profile tires. I haven't decided but am open to
any other suggestions.
Epil Stop & Spray Painless Hair Removal. Spray on and wipe off!
Just $24.95 at Youcansave.com
http://us.click.yahoo.com/gC2sGD/6jNDAA ... /XoTolB/TM
appreciated.
Grant
Daniel Wilson
Mods to 92 Legacy?
Pulley will make a reasonable increase a N/A will also be helped with
a lightened flywheel, will allow it to rev a bit better, the only
down side is you will loose a little torque.
With the pulley make sure you get one the same size as OEM as the
Subaru electrics don't like being under driven.
Dan
> appreciated.
> Grant
Pogo Stick - Just $24.95!
Great gift idea for kids of all ages, from Youcansave.com
http://us.click.yahoo.com/t5NeUC/QkNDAA ... /XoTolB/TM
Dan
> appreciated.
> Grant
Samuel Barrett
Mods to 92 Legacy?
Grant,
Unless you have a turbo, forget about doing anything to the stock exhaust -
waste of $$ until you have a turbo, performance wise that is... If you like
making noise with it and you want a louder, lower note, and "everyone else
at school has them" then go ahead. Whatever floats your boat. But people in
the know will make fun of you everytime we see you on the road with it.
On the wheels, step one: do a search on this forum for "offset". Then get a
cup of java and get comfortable, lots to read. Basically if you have
anything less than a +48 offset (I believe +52 is stock - but check me) then
you're in for some rubbing.
Pulley upgrade is reccomended by several on this list. Make sure you tighten
the bolt to 100Kn when you do it. Anything lower and you risk the life of
the engine. Do a search for more info.
01 = my two bits
-Sambo
-----Original Message-----
From: grantsubaru@yahoo.com [mailto:grantsubaru@yahoo.com]
Sent: Saturday, November 03, 2001 101 PM
Subject: [BC-BFLegacyWorks] Mods to 92 Legacy?
appreciated.
Grant
01 = my two bits
-Sambo
appreciated.
Grant
mike p.
Mods to 92 Legacy?
gotta agree with the exhaust deal. i just put a straight muffler on
my turbo and it did make a noticeable difference(after i ran it for a
few miles, it sat for a few days while under the knife and was a bit
cold i guess). granted it's an auto, it pulls a good bit more now
when i have it in Drive, i used to keep it in 3rd for the most part
(in town driving, etc) but now it seems Drive(4th) has a good bit
more power(doesn't sound bad either). i do love to see those young
ricers with their N/A cars with big @$$ exhausts hangin out though.
man what a laugh!
--- In BC-BFLegacyWorks@y..., "Samuel Barrett" <LEVATHIAN@s...> wrote:
> Grant,
exhaust -
you like
and "everyone else
people in
it.
Then get a
me) then
you tighten
life of
> 01 = my two bits
> -Sambo
> From: grantsubaru@y... [mailto:grantsubaru@y...]
> To: BC-BFLegacyWorks@y...
> appreciated.
> Grant
> grantsubaru@y...
on
any
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
man what a laugh!
> Grant,
exhaust -
you like
and "everyone else
people in
it.
Then get a
me) then
you tighten
life of
> 01 = my two bits
> -Sambo
> appreciated.
> Grant
> grantsubaru@y...
on
any
Daniel Wilson
Mods to 92 Legacy?
The biggest increase you will get on the exhaust front would be to
get some exractors made, N/A engines love that more so than turbo
cars. As for the rest of the exhaust not much gains for money spent.
georgerbyrne@yahoo.com
Mods to 92 Legacy?
I found that even just getting my headers cut off about 5cm out of
the block, (at their largest point) and then having 2 1/4 inch from
there to a smooth join, then into 2.5 inch and a high flow cat, and
2.5 the rest of the way back gave me some better power, and much
better accelleration for my N/A EJ22.
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/Pv4pGD/4m7CAA ... /XoTolB/TM
FREE COLLEGE MONEY
Rod Grosvenor
Mods to 92 Legacy?
Grant-The K&N filter, exhaust upgrade & STANDARD size lightweight pulley will all help quite a bit (probably good for 15-20 HP total.) Check Unorthodox for your pulley info & Cobb Tuning for your exhaust. You have to have a minimum of 53mm offset on your rims to work correctly (I believe that`s the correct number.) Without the correct offset, the tires will always be a problem. Good luck---ROD (AZ.)
----- Original Message -----
Sent: Saturday, November 03, 2001 111 PM
appreciated.
Grant
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1711356.32 ... 847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =466618121>
appreciated.
Grant
ADVERTISEMENT
Grant Hughes
Mods to 92 Legacy?
Sambo,
Thanks for your input. I think the stock offsett is
either 52 or 54 I can't remember but your pretty
close. I haven't figured out what I want to do about
it. I am either going to downgrade to a lower profile
tire or different wheels. One preson suggested to
phsically flatten the fender so it is straight and not
an L but I don't particularily like that idea. I was
thinking about looking into any fender flares but I
don't know if those would look good. As for the
exhaust I have pretty much tossed that idea unless I
were to add a turbo to my car. It seems pointless
since it is expensive and most likely won't help at
all.
Grant
--- Samuel Barrett <LEVATHIAN@sprintmail.com> wrote:
> Grant,
> 01 = my two bits
> -Sambo
> Legacy L and was
> KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> and the offset on
> whenever I hit any
> tire. Has anyone
> trade out the
> but am open to
> to:
Do You Yahoo!?
Find a job, post your resume.
http://careers.yahoo.com
all.
Grant
> Grant,
> 01 = my two bits
> -Sambo
> Legacy L and was
> KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> and the offset on
> whenever I hit any
> tire. Has anyone
> trade out the
> but am open to
> to:
Do You Yahoo!?
Josh Colombo
Mods to 92 Legacy?
Grant,
I am pretty sure stock backspacing is +52mm. I can tell you from
personal experience that you will not be able to fit any larger rim on
your car unless it has a +45mm backspacing or more. I have a 90 Legacy.
I searched for over a year to find wheels that fit on this car and still
looked good. My stock tire size is 175/70 r14. I was originally going
to put on 195/50 r15, that rubbed like a mother, then tried 205/50 r15.
Still rubbed, and I tried those tires on two different rims, one with
+35mm backspacing, the other had +38mm backspacing.
Well anyway, after about a year of looking here and there, a buddy at a
speed shop told me he had a friend who worked for discount tire. He
ended up finding me a set of Japanese racing wheels. They had a +45mm
backspacing and were 16". So I went with the tire size 205/45 r16.
This tire gave me the closest overall tire diameter to the original.
Well after all that and finally finding wheels, which at the time were
about double what a "normal" painted set of 16" wheels cost, they still
rubbed a little. I brought my car to the buddy I have in a speed shop.
He pulled back the trim in the rear fender, and shaved that lip down,
tapered it very nicely, and then applied a new piece of trim. It
WORKED!! It looks fine, it doesn't have cheesy looking flares on it to
interrupt the lines of the car.
Here are the links to the pics in the photo section.
http://photos.groups.yahoo.com/group/bc ... =/&.src=gr
&.dnm=Josh%27s+Fender+Trim+1.jpg&.view=t&.done=http%3a//photos.groups.ya
hoo.com/group/bc-bflegacyworks/lst%3f%26.dir=/%26.src=gr%26.view=t
http://photos.groups.yahoo.com/group/bc ... =/&.dnm=Jo
sh%27s+Fender+Trim+2.jpg&.src=gr&.done=http%3a//photos.groups.yahoo.com/
group/bc-bflegacyworks/vwp%3f.dir=/%26.dnm=Josh%2527s%2bFender%2bTrim%2b
1.jpg%26.src=gr
sh%27s+Fender+Trim+3.jpg&.src=gr&.done=http%3a//photos.groups.yahoo.com/
2.jpg%26.src=gr
You can also check out more pics of my car on my site
www.personal.psu.edu/jcc189/subaru/subaru.html
Josh Colombo
jcc189@psu.edu <mailto:jcc189@psu.edu>
of beats and rhythm" - ME
Sent: Saturday, November 10, 2001 1:56 AM
Subject: RE: [BC-BFLegacyWorks] Mods to 92 Legacy?
Sambo,
all.
Grant
> Grant,
> 01 = my two bits
> -Sambo
> Legacy L and was
> KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> and the offset on
> whenever I hit any
> tire. Has anyone
> trade out the
> but am open to
> to:
Do You Yahoo!?
1.jpg%26.src=gr
2.jpg%26.src=gr
Josh Colombo
Sambo,
all.
Grant
> Grant,
> 01 = my two bits
> -Sambo
> Legacy L and was
> KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> and the offset on
> whenever I hit any
> tire. Has anyone
> trade out the
> but am open to
> to:
Do You Yahoo!?
Mods to 92 Legacy?
Grant,
You can have your guards rolled at most tire places. They have a
machine that attaches to your rotor (i think) and it rolls around
your guard and flattens out that L shape. Doesn't hurt the car at
all, still lookes the same, only you can fit bigger rims in!
George Aus.
--- In BC-BFLegacyWorks@y..., Grant Hughes <grantsubaru@y...> wrote:
> Sambo,
> all.
> Grant
> --- Samuel Barrett <LEVATHIAN@s...> wrote:
> > Grant,
> > 01 = my two bits
> > -Sambo
> > Legacy L and was
> > KN filter last
> > looking into a
> > the stock pulley
> > stories would be
> > appreciated.
> > Grant
> > grantsubaru@y...
> > and the offset on
> > whenever I hit any
> > tire. Has anyone
> > trade out the
> > but am open to
> > to:
> Do You Yahoo!?
Universal Inkjet Refill Kit $29.95
Refill any ink cartridge for less!
Includes black and color ink.
http://us.click.yahoo.com/E11sED/MkNDAA ... /XoTolB/TM
George Aus.
> Sambo,
> all.
> Grant
> > Grant,
> > 01 = my two bits
> > -Sambo
> > Legacy L and was
> > KN filter last
> > looking into a
> > the stock pulley
> > stories would be
> > appreciated.
> > Grant
> > grantsubaru@y...
> > and the offset on
> > whenever I hit any
> > tire. Has anyone
> > trade out the
> > but am open to
> > to:
> Do You Yahoo!?
Grant Hughes
Mods to 92 Legacy?
Any suggestions on size for a custom exhaust? Thanks
for your suggestion on the pulleys. Saved me a ton of
time in the long run.
Grant
> Legacy L and was
> a KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> whenever I hit any
> tire. Has anyone
> to trade out the
> ADVERTISEMENT
> email to:
> Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of Service.
Do You Yahoo!?
Grant
> Legacy L and was
> a KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> whenever I hit any
> tire. Has anyone
> to trade out the
> ADVERTISEMENT
> email to:
> Terms of Service.
Do You Yahoo!?
Rod Grosvenor
Mods to 92 Legacy?
Grant-Glad I could help on the pulleys. There are many theories on exhaust size but what you`re ultimately going to do is the determining factor. If it`s going to be a `touring car` with maximum boost of 9 psi with an IC, your engine will probably like 2.25 to 2.50 diameter. Too much size will kill the torque on the bottom end. Now, if you`re going to run above 9 psi (possibly to 18psi or more), you`ll want a 3" system from the collector back. My combo for the street is as follows: Borla headers (for an NA motor) with a 2.25" collector into a 2.25" pre-cat tube-2.50" hi-flow cat to a 2.25" system (all mandrel bent) to a low back pressure Dynaflow muffler. It`s a little loud under full throttle, but very reasonable inside/outside with normal driving. Remember, I run a very quick-spooling turbo on an NA motor with 9.5 compression @ 6.5 psi boost. This makes it very torquey at the bottom end, but runs out of breath at about 5500 rpm (this will be remedied with the MSD ignition & a little head work.) So, my exhaust requirements are different than guys with lower compression & higher boost. My next motor will have 9-1 compression with forged pistons, reworked rods & stroker crank (to 2.4 liters) with appropriate cam timing & head work for a TORQUE motor (remember, HP is a derivitave of torque, not the other way around.) With all the right pieces, it should make around 325 to 350 HP; the rest of the equation will include a wet nitrous system of about 150 HP (to be used in 3rd & 4th gears mainly.) I have, when I did`nt know any better, run way too much cam timing, compression, gearing, etc., to be viable for the street. My current set-up and the new one are both designed to live in the real world. BTW, my new set-up will probably run 2.50 exhaust diam. initially & will be dynoed for the correct combo. Hope this has helped---ROD (AZ.)
Sent: Sunday, November 11, 2001 12:39 AM
Subject: Re: [BC-BFLegacyWorks] Mods to 92 Legacy?
Grant
> Legacy L and was
> a KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> whenever I hit any
> tire. Has anyone
> to trade out the
> ADVERTISEMENT
> email to:
> Terms of Service.
Do You Yahoo!?
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.1727639.32 ... .tf?s=5085>
<http://us.adserver.yahoo.com/l?M=213858 ... =935020898>
Grant
> Legacy L and was
> a KN filter last
> looking into a
> the stock pulley
> stories would be
> appreciated.
> Grant
> whenever I hit any
> tire. Has anyone
> to trade out the
> ADVERTISEMENT
> email to:
> Terms of Service.
Do You Yahoo!?
ADVERTISEMENT
