What tells the fuel pump to pump?????
TheSubaruJunkie
My car died last night. Left me stranded 75miles from home.
I pull the fuel line leading to the filter, crank the motor, nothing comes out....
What tells the pump to start pumping?? Is it the ECU? Does it use the crank angle or cam sensor? I pulled codes and im getting 11, 23, 49... there is one other, it was 2am on the side of the road so the codes could be wrong. I'll check again tonight for the codes... i know there were four.
Not sure where to check first.
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
1986 Toyota 4Runner
It should prime for a couple seconds when you turn the ignition to the on position. If that's not happening, your main relay could be at fault. This happened to a friend of mine. If that relay is bad, you'd also have to power to your injectors or ignition coil.
The main relay is in the upper left corner of the dash. The only way I know to get at it is to remove the dash somewhat. You don't have to completely remove it from the car, but it needs to be loose enough to pull away several inches.
TheSubaruJunkie
Matt Monson
- quasi-mod-o
The ECU tells the fuel pump to pump. It then sends a signal to the fuel pump relay, which is right next to the main relay, which turns it on. It turns on in the accessory position before you ever crank the car and try to turn it over.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
TheSubaruJunkie
I put the car into d-check mode and tested for voltage at the pump. It cycles 12v, so i know the pump should be getting juice. When I plug the pump back in, it does nothing.
I tapped on it with my ratchet and it came to life for a split second then stopped. Only did that twice then it did nothing.
Guess tomorrow im getting a new fuel pump
1986 Toyota 4Runner
1986 Toyota 4Runner
Matt Monson
- quasi-mod-o
An $85 Walbro works just as well as the $2-hundred and something stocker.
I've got some used JDM pumps if you want to give one of them a shot. PM me if you are interested.
Suby Hai!
Suby Hai!
TheSubaruJunkie
Matt Monson
- quasi-mod-o
Yes,
They are specific to the turbo. The turbo pump flows more.
My local Subaru dealership stocks the Walbros, as do several speed shops in the area. It's a pretty common upgrade. Any shop supporting "stage 2.5" or above for the WRX will have the pump.
Suby Hai!
Suby Hai!
I was gonna say little fairies make your fuel pump turn on...but it appears I am wrong...
Now...enough of the silliness...
If you are interested, I have a working used turbo fuel pump I could part with for pretty damned cheap
I have my stock turbo pump in good shape that you can have for $25 plus shipping ?
If you want to see if its your pump, pull off the access panel, then pull out the pump. Itll take you 20 mins. Grab a batter charger, and hook the positive and negative clamps to seperate nails (yea the kind you hammer into walls). The pump will have a positive and negative side, touch the pos nail to one, neg nail to another and plug in the charger and see wat happens.
Matt Monson
- quasi-mod-o
TheSubaruJunkie
Or I could just use the proper tools. Probe 12v from the battery and feed it directly to the pump while its installed.joshm wrote:I have my stock turbo pump in good shape that you can have for $25 plus shipping ?
or better yet, I could test the harness for 12v signal and verify wether or not the pump is working. I think i'll do that instead of sticking nails into my fuel pump.
If I call the dealership and ask for this Walbros pump... is there a part number I can refference?? or do I just ask for a Walbro pump for a Legacy Turbo 2.2???
1986 Toyota 4Runner
1986 Toyota 4Runner
Matt Monson wrote:The ECU tells the fuel pump to pump. It then sends a signal to the fuel pump relay, which is right next to the main relay, which turns it on. It turns on in the accessory position before you ever crank the car and try to turn it over.
Oops, that's right. There is a separate realy for hte fuel pump, next to the main relay. Its been a while since I've messed with my wiring.
Pump: GSS341
WRX fuel pump conv kit: 400-791
I highly recommend getting the kit. It makes everything a truly plug and play operation.
TheSubaruJunkie
ultrasonic
Also check the fuel pump wiring harness connection under the rear seat on the passenger side. The connector can corrode, causing extra resistance, which then draws more current. The wiring is marginally spec'd in the first place and the extra current being drawn through it makes it worse. The signs to look for are brown/black discolored connector, and browned crispy wire.
Do a search to find more specifics.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
Dynamic Entry
