ENGINE PROBLEMS SOLVED!!!
Mrkillem
Post by Mrkillem »
Ok i was on here before and had a weird engine problem i couldnt figure out so i decided to take off my balancer and take a look at my timing and this is what i found!!!
so obviously i need to get a new crank because its stripped to high heaven so i will be doing a rebuild!!!
just remember TORQUE that bolt down HARD!!!!!!!!!!!!!!!!
Shawn
Saskatoon Subaru
Post by Saskatoon Subaru »
i rebuilt my 90 L engine in Jan/08-March/08 Due to the same problem
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Mrkillem
Post by Mrkillem »
yea its weird ive known a couple people who have had the same problems. it seems like a crappy design.
i was thinking about just taking in a crank to a machine shop and having them cut a regular rectangle keyway into the crank for more contact area for the pullys and timing sprocket.
whats everyones input on doing that?
Shawn
The design isn't bad. The misprint in the factory manual which trickled down to all the other manuals is what is bad. I'm sure that little simple misprint has caused oodles of fubared motors due to the crank pulley coming loose.
