My 97 lgt rear diff accepts male axles. These axles, when removed, should have circlips on them right? cuz they don't. This means they are likely in my diff, Correct?
If so, any tips or tricks on finding and removing them? What if I can't find them?
*** Next question:
I can't seem to get either rear axle out of the donor car. Both hubs are refusing to let go of 'em.
Of course , this leads me to wonder if it's possible to pop the stubs out of my touring wagon's old diff and pop them in to the 97 diff. allowing me to use my stock 94 axles.
Will the stubs fit? Can they actually "pop" out or do i need to deal with that torx head bolt in there? I'm sure it couldn't be that easy... could it?
I don't want to get too crazy with swapping ring and pinion etc.. (barely even have a grasp of what that means)
I'm trying to avoid buying new rear axles if i don't have to since I have 2 perfectly good sets of rear axles for the 94.
*** part 3:
If the swapping of the stubs is a no-go, howz about taking apart the inner cv joints of both cars and putting the 97 ends on the 94 axles? Another long shot probably, but... er... maybe.
I'm so cheap.
