Transmission Gearing
Locked
legacycentral
Post by legacycentral »
The discussion has been raging, and we're still not sure what's going
on. Manuals may have it wrong, and chaos reigns....
I refer you to the press packet from 93 that i scanned in here:
http://www.xmission.com/~dac/library/93_packet_info.htm
Under the Sedan, it states that the MT/FWD, MT/L/AWD and AT/FWD FD is
3.7. AT/AWD is listed as 3.9, while MT/AWD is 4.111.
The Sport Sedan is MT/AWD in most/all of these cases we're talking
about, so it *should* be 4.111 gearing.
The Wagon does differ slightly. MT/FWD is 3.7, AT/AWD and AW/FWD are
3.9 while MT/AWD is again 4.11. I'll be damned if they never put the
MT/AWD in the Touring Wagon, but i'll remedy that soon enough.
John from Subaru/Suzuki/Kia is sending me what should be a Legacy
Turbo transmission and LSD from a 93. They're 4.111 gears. He said
that the 91 had 3.9 in the MT/AWD but that most 92-94 had 4.111.
I wish i could find 91, 92 and 94 press packets...the 91 Legacy
Dealer brochure i have doesn't go into gearing.
Monitoring Service trial
http://us.click.yahoo.com/ACHqaB/bQ8CAA ... /XoTolB/TM
Josh Colombo
Post by Josh Colombo »
Dave,
Just curious....where are you finding your press releases, and scanned packets?
-----Original Message-----
From: legacycentral [mailto:legacycentral@yahoo.com]
Sent: Fri 2/1/2002 8:40 AM
Cc:
Subject: [BC-BFLegacyWorks] Transmission Gearing
legacycentral
I just buy them from people on eBay.
Don't be swooping me now :D
--- In BC-BFLegacyWorks@y..., "Josh Colombo" <josh@s...> wrote:
> Dave,
scanned packets?
> Josh
> From: legacycentral [mailto:legacycentral@y...]
> To: BC-BFLegacyWorks@y...
> Cc:
what's going
here:
AT/FWD FD is
talking
AW/FWD are
put the
Legacy
4.111.
Legacy
> Dave
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Access Your PC from Anywhere
It's Easy. It's Fast. - Free Download
http://us.click.yahoo.com/lmECdA/6XkDAA ... /XoTolB/TM
aludeman
Post by aludeman »
OK! here is what i found. I have the 1992 subaru legacy service manual sitting in front of me.
manual transmission section:
fwd non turbo: 3.700
awd non turbo: 4.111
awd turbo: 3.900
automatic transmission section
(no classification between turbo/non turbo):
fwd: 3.7
awd: 3.9
i also have the subaru parts manual(this was nice score i might add) and what i read in the notes section about the rear diff:
91-92: model l,ls,ls.d = 4.111
91 : model turbo with LSD= 3.9
92-94: AT model l,ls, turbo= 3.9
92-94: MT model L = 4.111
i did a conversion from auto(1993) to manual(1991). Since i'm not hearing massive noise/smoke coming out of my center diff I'm pretty sure I have 3.9. The back of my rear diff is marked 3.9.
honestly I wouldn't believe too deeply in a press packet.
ok i got some magic to read your transmission id.
1234567890 <-- place in TIN
tz102zj3aa <-- my AT
ty752vj1aa <-- my 5 speed MT
1: t=transmission
2: A=2wd AT, M=2wd MT, Z=Full Time 4wd AT, Y=Full Time 4wd MT
3&4: distance between gears
5: 2=series code
6: A=2wd 4at, R=2wd 5f(75 distance between gear),
V=full time 4wds/R(center diff & viscuss type)
Z=full time 4wdd/R(Multi Plate Type)
7: A=2200cc EMPI, J=2200cc TURBO
8: 1=1990, 2=1991, 3=1993, 4=1994
9&0: no meaning
lex
Brian White
Post by Brian White »
Where did you get the service manuals? Are they worth
purchasing? I'll probably have my car for a long
while, so I was already thinking about trying to find
the service manuals. Any help would be greatly
appreciated. TIA.
-Brian
> awd turbo: 3.900
> fwd: 3.7
> awd: 3.9
> packet.
> 1: t=transmission
> Time 4wd MT
> 5: 2=series code
> 9&0: no meaning
> lex
> to:
Do You Yahoo!?
Send FREE Valentine eCards with Yahoo! Greetings!
http://greetings.yahoo.com
subman2001nz
Post by subman2001nz »
That's interesting
In New Zealand our ratios are as follows
non turbo/turbo FWD: 3.90 Non LSD/LSD
non turbo/turbo AWD: 4.11 LSD only
non turbo/turbo AWD: 4.44 LSD only - Late model only mainly found in
WRX's
Dan
Locked
