Time to unload a few things
PhyrraM
Post by PhyrraM »
More to come, so keep checking back.
All prices are my un-educated guesstimates. Feel free to make offers.
First up is an authentic JDM intake filterbox. While this may appear to be exactly the same as our USDM filterboxes, rest assured it is only the same in function only. Comes with an origninal OE JDM Subaru air-filter! It's used but still has at least 10 miles of usable life left in it. This not-as-rare-as-I'd-like-you to-think airbox has got to be good for AT LEAST as much HP as your factory one. Does have a broken clip for a hose, not sure if it's even used on the USDM cars. Great if you need a spare for expirementing or a fast swap if you are playing with the JECS AFM.
$20+shipping?
Next we have a factory Clarion radio w/CD player. Works fine, even the CD player. A few blemishes, but very presentable. Comes with the DIN side mounting brackets.
$100+shipping
Airbag module. Great un-exploded condition. Pop yours? Need a replacement, or a spare? Not sure how many of these are left in circulation.
$120?
EJ25D intake manifold. This particular one is supposedly from a '98 2.5RS. Has EGR valve, throttlebody, injector/fuel rails, IAC valve. Layout is basically the same as the EJ22T intake manifold. An EJ22t harness and coilpack would drop on this thing. Could be a great DOHC donor manifold for a project. TPS has a different connector, but an EJ22T thottlebody (w/TPS) is a bolt on. Might need to get a bit creative with the TB/IAC water lines an the PCV lines. If your already planning on a catch-can setup--perfect!
$150+shipping
Airbag steering wheel. A bit rough on the outside, but I've seen worse. Rewrap it while you still drive with yours.
$30
Hi-rez pics here: http://flickr.com/photos/23291496@N04/s ... 605899752/ Click on "all sizes"
You're funny.
smh0101
Post by smh0101 »
Would you separate the fuel rails from the intake manifold?
PhyrraM
Post by PhyrraM »
smh0101 wrote:Would you separate the fuel rails from the intake manifold?
Not at this time, but keep checking in. I've got some fuel rails in the barn. They might even be the right ones!
Also, if the manifold doesn't sell I will sell just the rails and dump the aluminum hunk.
smh0101
Post by smh0101 »
Well, I have the aluminum hunk... I just need the IAC and Fuel Rails, so if you wanna ditch the hunk... I'll take the other two.
smh0101
Post by smh0101 »
Free bump.
(I still want the rails! lol)
