need to know if this will fit?
RJ93SS
Post by RJ93SS »
coming from...02 wrx wagon
going on... 1993 legacy ss
SPT pink springs with Group-N tophats and Koni inserts (prefer to sell as a set!): Asking $800 for the whole shebang. Paid over $1200, total. I'll throw in the Turn-in concepts travel extenders (which I didn't end up installing) as well. Less than 15,000 km on this setup.
thanks
RJ93SS
Post by RJ93SS »
somebody has to know???
subaru_styles
Post by subaru_styles »
it will fit, however you will need different top mounts in the rear. your stock ones or GC impreza will work.
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
Yup, I got wrx sedan struts though on my wagon, the rear top mounts are different. Everything else works 100%. Also for the brake lines, I just tie wrapped it to the strut in a X to the brake holder spot.
RJ93SS
Post by RJ93SS »
so if i buy this set i will not need to buy anything else?, just use my stock top mounts in the rear?
also going from a wrx wagon to a legacy sedan, will that effect ride height compared to if it was to come out of a sedan?
last question, if i don't go with this setup and i was to do more of a basic swap, could i use a specific wrx stock strut and just buy the group n top hats for the front?
sorry for all the questions, i'm just starting to learn about suspension. much appreciation for the answers!
RJ93SS
Re: need to know if this will fit?
Post by RJ93SS »
RJ93SS wrote:coming from...02 wrx wagon
qoute from seller
"SPT pink springs with Group-N tophats and Koni inserts (prefer to sell as a set!): Asking $800 for the whole shebang. Paid over $1200, total. I'll throw in the Turn-in concepts travel extenders (which I didn't end up installing) as well. Less than 15,000 km on this setup."
thanks
RJ93SS
Post by RJ93SS »
subaru dropped out of the wrc today
RJ93SS
Post by RJ93SS »
bump, anybody?
The front will be fine, the rear might sit a BIT higher. I doubt it though. I used sedan struts on my wagon and my car sits really good, the rear does not sag at all. Only thing I noticed was the wrx top hat made the rear sit lower, and my stock top hat makes the rear sit higher. (i still can't use wrx top hats unless i redrill the holes though). Install them though and see how the rear sits. Don't be discouraged the first time you drop the car either. It will need to settle a bit when you drive around.
RJ93SS
Post by RJ93SS »
now if the springs that come with this set are tapered in the rear then i will not be able to use my stock tophats right?
RJ93SS
Post by RJ93SS »
after doing some more research and with all of you help, i'm almost there. however, he used 04 tophats and 04 springs. any chance i can get 04 rear tophats in my car? 93ss????
