Injector mods
douglas vincent
Post by douglas vincent »
The aluminum shroud needs the "medieval" work. No other way to get it off.
dropdfocus
Post by dropdfocus »
PhyrraM wrote:A belt sander. Gently ground down the tip of the injector at about a 45 degree angle, while rotating it evenly, until the 'cover' popped off. You can see the cover piece on the counter top in the pics. You can also see the sanding lines on the injector tip if you look close.
Jason
I got that part already. I tried on one too, but it didn't have that big aluminum tip on it.
Where can I get the plastic caps for them? I've been looking for a while today and all I can find are the Bosch style caps.
douglas vincent
Try Doctor Injector. I picked up 8 from the local one in Portland
94legacy2.2
Post by 94legacy2.2 »
Back from the Dead
Did anyone send a set in to be flow tested? If so what did they test at?
If not I have about 28 injectors to send in for testing. I will match the best with a set of 4 and then sell them.
Plans are to have 1 or 2 MOD'D injectors tested first, if they test out more then 480cc then Ill have them all done, if its under 479cc then I wont have them done.
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
douglas vincent
Actually this mod isnt useless at all.
I took my 270s, CAREFULLY ground the tips down to expose the pintle, and WITHOUT flowtesting (cause thats the way I roll), I am running fucking perfect, and 20psi out of T3T4 turbo.... Maybe not safely :? , but while getting the AVC-R working today, I hit 20psi many times. No lean issues.
The modded 270s are the BEST value out there if you are careful.
94legacy2.2
but what do they flow?
My megasquirt needs to know the flow rate of them for fuel calcs
But thanks for posting it. I still will send mine in to Witchhunter for service
Florin1
Re: Injector mods
Post by Florin1 »
from the dead... anybody got flow rates?
it was a good read, so why not...
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
jeffdoubleu
Re: Injector mods
Post by jeffdoubleu »
long term report?still running good?
Re: Injector mods
curious aswell
