seafoam
seafoam
i bought some seafoam and am planning on running it thro. ive looked around and see that the PCV hose is the place to run it thro...haha but which hose is that??
nooby i know.
nooby i know.
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
The best way to run the seafoam through the pcv is to remove the valve out of the intake mani. and get a vac hose small enough to fit into the pcv valve hole, run it from the can to the hole, and it'll suck it right up.
Be careful not to flood the engine, just do a little at a time.
Also, you'll need to either fiddle with the throttle while you do this, or have someone on the gas pedal, otherwise the car will stall at an idle with it removed.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
awesome thanksBdub wrote:The best way to run the seafoam through the pcv is to remove the valve out of the intake mani. and get a vac hose small enough to fit into the pcv valve hole, run it from the can to the hole, and it'll suck it right up.
You were told wrong. The PCV valve dumps right into the main airflow of the intake. Seafoam here will go to all cylinders.
And +1 (got it correct this time Nate
) to Nate's suggestion to use the brake booster vacuum line. It doesn't distribute quite as well, but after half a can, I'm inclined to think you're getting enough everywhere. That is the location I personally use.
Lee
oh ok, thanks for clearing that upskid542 wrote:You were told wrong. The PCV valve dumps right into the main airflow of the intake. Seafoam here will go to all cylinders.
And +1 (got it correct this time Nate) to Nate's suggestion to use the brake booster vacuum line. It doesn't distribute quite as well, but after half a can, I'm inclined to think you're getting enough everywhere. That is the location I personally use.
- quasi-mod-o
In terms of central location, the PERFECT place to induct any kind of top engine cleaner is that purge valve vacuum hose right on top of the throttle body... you can see it clearly in that picture. Not only is it centrally located and has the best chance of even distribution to all cylinders, it is small enough that flooding or hydrolocking the engine would be pretty difficult.
However, that engine cleaner might wash the beneficial black goo off the throttle plate. The jury's out on that one.
i did it today, but it didnt really smoke all that much, so i dont think i put enough in the intake, it took forever for it to suck it all upTleg93 wrote:You may also run it through the gas and oil.
I want to know how black goo anywhere in the intake tract can be beneficial.DerFahrer wrote:However, that engine cleaner might wash the beneficial black goo off the throttle plate. The jury's out on that one.
On my old Jetta I cleaned a ton of block goo off the mechanic MAF plate and the throttle blades and that thing went from a snail to a snail with better throttle response.
in the gas it's a horrible cleaner. Seafoam is best used as a top end cleaner through sucking it in while running..joeWM wrote:i did it today, but it didnt really smoke all that much, so i dont think i put enough in the intake, it took forever for it to suck it all upTleg93 wrote:You may also run it through the gas and oil.
Everyone says to use a hose and put it in the can but I did that and even with a lot of throttle it still killed the engine pretty much instantly.
I just got a hose with a small funnel in the end of it and poured it in a little bit at a time while holding the throttle open probably 3-4K rpm and then when I had about half can in there I let go of the throttle and let it suck up enough to kill the motor and let it sit for 15 mins. Then started it up and took it for a spirited drive to burn it all off. I never noticed any difference on that car but I never had any problems with the motor to begin with.
The other legacy I did it on had really bad lifter noise afterwards. But after a day or two the noise went away. I was pretty freaked out during that time though. Thought I had fucked up the motor.
- quasi-mod-o
The airflow restriction (especially under light throttle) doesn't cancel out that benefit?DerFahrer wrote:From what I understand, the black goo that surrounds the throttle plate helps seal it closed, thus allowing more accurate air metering through the IAC valve and giving a more stable idle.James614 wrote:I want to know how black goo anywhere in the intake tract can be beneficial.
I've never heard of a car where the throttle blade(s) worked in any better condition than squeaky clean. But then again, not too many people clean the rest of the intake and leave the TB dirty for comparison, so I dunno... Sounds plausible.
The TB's with the needle valve adjustment.....if you remove the black sealant, you'll cause yourself issues especailly if you don't know about the sealant. You'll have a high idle and can't figure out why. Been there, done that, cussed a lot.
http://www.main.experiencetherave.com/subaru/images/TB/
So, is that goo pre-applied or build-up? Looks pre-applied, but the context I've heard it used in implies a build-up? (otherwise I'd think you guys would refer to it as actual sealant)
It's pre-applied from the factory.
