I'm looking into to getting some DOHC heads off of a 1997 legacy GT. I am wondering what else will need to be done to get these heads to work with the EJ22T block, will stock internals be ok or should i rebuild it. any suggestions are welcome.
thanks in advance.
DOHC info. needed
The DOHC thread doesn't cover adding the oil/coolant passages to the USDM heads yet.
Essentially this is what you will need to do:
![Image](http://farm4.static.flickr.com/3222/2289707803_56a1c43671_b.jpg)
Or you run it to the oil pan if you're not comfortable drilling into your cyl. head.
