So my EJ20G is missing one of the lower studs that feeds through the transmission. So I can only tighten the engine to the transmission in 3 places. I'm assuming it's a stud, since I tried to thread in one of the bolts for the top side of the engine, and it didn't thread.
How do I obtain a new stud?
Replacing engine->tranny studs?
You should still be able to thread a bolt into that hole, although you might have to pull the axle to get it in the hole. Same threads and length as the two upper bolts.
http://www.slodriveracing.com
-And more!
-And more!
They are usually not that tight.
1. Carefully with a pair of Channel Locks or Vicegrips. Try not to make gouges. Any small gouges can be filed down afer removal.
or
2. Two nuts of the same size. Lock them together then turn out the stud.
or
3. A commercially available stud remover. Most autoparts stores will have one.
or
or
