miss fire
Airgne
miss fire
Post by Airgne »
so ever since i bought the car it has had a miss. i have changed the plugs, wires, fuel filter, and cleaned air filter. anyone have any ideas on what it could be? i do have an extra diamond coil. should i change it out?
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
Skruyd
Post by Skruyd »
How bad of a miss fire, random or out of the same cylinder? Check engine light? Any who, check the coil, compression, and injector. How did the other plug look like when you took it out?
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
Airgne
Post by Airgne »
no check engine light. other plugs looked almost normal(alittle hot). cant tell if its off the same cyl. compression good. 174,172,174,175. im going to change the coil sunday, or ill jsut wiat tell i get the intake done(might have something to do with it).
Skruyd
Post by Skruyd »
What are you having done to the intake?
06 ZZR600
Airgne
Post by Airgne »
intake really is not stock at all. the turbo inlet elbow broke so had to make one. i made the turbo silencer and elbow in one. so i have crankcase pressure going back into the intake. i know i have a vaccum leak/problem, but the miss fire happened before the intake show happened.
Skruyd
Post by Skruyd »
ahh ok
06 ZZR600
What rpm is the mis?
Airgne
Post by Airgne »
mainly around 2k-3k
Check the wiring going from the ECU to the ignitor & coil pack.
