Anyone got one they can part with for cheap. I discovered on the harness side of the connector, that the little blue wire has a break in insulation and corrosion has set in. This is a 2.2L N/A AT Wagon BTW. Dirt Cheap and in good shape preferred Need about 4-5" of tail
