1995-1999 Subaru Legacy and Legacy Outback parts unless otherwise stated. Prices are stated as shipped / pick up, ex: $5 SHP/$1 PU. If you want more than one things I will gladly readjust shipping costs. I'm afraid I do not know the working condition of the parts, except the hatch parts, they're all good.
Hatch parts:
-Upper interior trim including high-mount light, $25 SHP/$15 PU
-Complete wiring harness, $20 SHP/$10 PU
-Hinges, $10 SHP/$5 PU
-Rubber stoppers, $4 SHP/$1 PU
-License plate lights, $10 SHP/$5 PU
-Brake/reverse light bar (small hole above lock, no damage done to actual light housings so it will pass inspection), $50 SHP/$20 PU (shipping 52" is a bitch)
-1990 to 1996 2.2L engine (except trubo) ignition coil and igniter, $25 SHP/$20 PU
Interior bits:
-Stock shift knobs, $6 SHP/$1 PU each
-Shift boot and surround, $11 SHP/$1 PU
-Handbrake surround (light damage) and heated seat switches, SOLD
-2000 to 2004 Legacy/Outback shift boot, $6 SHP/$1 PU
-Door lock timer, $6 SHP/$1 PU
-Bump sensor (I think)(you need keyless entry module), $6 SHP/$1 PU
-1990 to 1994 driver window switches , $6 SHP/$1 PU
