Personally, I disagree with a lot of what adam says, i also disagree with
seemingly every post of his turning into an advetisement for his tuning
facility.
I also disagree with a tuning shop asking questions on how to do things -
i'm not getting paid to help his company; he should be putting in the time
on his own. If a tuning facility is asking ME for advice on how to make
something work or if something will fit; then i expect some sort of
consultant reimbursement for my knowledge that will potentially generate
large profits for someone elses facility.
Yes, the intercooler from a USDM 2002 Subaru Impreza WRX will fit in the
engine bay. Yes, it requires some custom hoses to be made to make it work
with our stock turbo.
-Jason
>Jason,
>There seems to be a concensus that the '02 WRX intercooler will physically
>fit
>in my engine bay. But are you saying that you disagree with Adam's
>assesment
>that the intercooler won't work without a different turbo with a 90 degree
>elbow?
>Fred
disagreements
Z1Auto@aol.com
disagreements
I never said the turbo won't work, nor did I said the USDM WRX intercooler
wouldn't work. In fact I referred to a thread on i-club where a Leagcy Turbo
owner had fitted one, and I know of a few people here who have done it as
well.
In reference to the WRX turbo (USDM) fitting on a Legacy turbo, again I
referred to the same i-club post. I also stated that it would rquire a 90
degree elbow on the USDM WRX turbo in order to mate up with the standard
Legacy turbo intake.....or a custom intake pipe.
Lastly, the questions I have asked the members here about the Legacy were in
specific reference to my own car...not a customer car. if you are somehow
under the impression that I ahve "taken" knowledge and somehow profitted from
it, I have not. As you are probably well aware, there is exactly a large
market out there for BC-BF parts and accessories. All I ahve done is simply
ask questions about people who have owned the car longer than I have; in
return, I have provided any and all information I have learned from our Japan
contacts, etc. in terms of parts available, in addition to what I have
personally discovered as having worked or not worked.
And lastly, if you been that by advertising I have our website listed in my
signature line, then I apologize - it has been removed for purposes of this
list.
On a final note, I am not particularly interested if you agree or disagree
with my assesments. And for the record I don't take offense that you do
disagree...that is your right and it is one of the purposes of the list - for
everyone to contribute information they know, and have other squestions it,
or present alternative theories, in hopes of assisting others with their
question(s).
well.
list.
question(s).
FREDERICK.WHITMORE@CN.CA
disagreem
Now now guys lets not fight.
We all have our own opinions but we can't be right 100% of the time. Thanks
for your help!!!
Based on the pictures I've seen and from what I remember the 2002 WRX engine
bay looking like the new intercooler is bigger than the 93-96 WRX intercooler
and is not slanted. I'm worried that my turbo coolant tank (which I don't
want to re-locate) will get in the way of the new style intercooler. I
really want to keep things somewhat simple and don't want to start messing
with that coolant tank. I've seen picture of the 93-96 intercooler with the
coolant tank in it's standard spot which is encouraging. Do you guys know if
the coolant tank presents a problem with the 2002 WRX intercooler? Also I'd
really appreciate it if someone could give me the part# for the 93-96 WRX
intercooler. Doesn't anyone have it?
Adam I'm sure you must know what it is.
Thanks,
Fred
for your help!!!
Thanks,
Fred
Z1Auto@aol.com
disagreem
Fred - I am not sure what the part # is, though we can easily get used ones.
On the 93-96 IC, you need to cut off one of the mounting tabs (drivers side) in order to have the coolant tank fit in the OEM location. I chose to leave the tab and simple rotatwed the coolant bottle 180 degrees so though it now only has one mounting screw (vs 2 stock) is holds well and there is room enough for the IC mounting on either side
On a 2002, the coolant tank will definately need to be moved...not hard to do, just another step!
Adam
Adam
