i have my battery in my trunk and i dont remember if the hose gets in the way but be creative, it'll work.
i started by pulling the bottle out and taking the pump off.
then i extended the wiring for the pump a couple of feet.
then i cut a hole in the yellow lid and stuck a hose inside and taped the shit out of it to seal it and keep the hose attached to the bottle.
then i pulled off the bottom fender cover and placed the bottle inside with the hose coming out the hole pictured above. put the cover back on.
i still need to bolt the hose to the wall so it doesn't stick out like it does. but it defintely free'd up some room in my engine bay.
when i fill it i just grab a filler cone to and i'm good to go.
watch out for airbag sensors
