2wd trans problem
justin the subie
2wd trans problem
Post by justin the subie »
so aperently i messed up the trans pump when i installed a new motor... the engine runs great but the trans will no longer go in gear..
options i have at the moment are,
Swapping over to 4wd Auto,
or a Turbo 4wd Auto,
or taking the trans apart and fixing the pump..
any advise for the best fix is greatly aprecated :smt033
'92 TW "Hana" ej20tt obd1 <too many to list< sold :-( bought back :-)
Re: 2wd trans problem
Well, the AWD transmissions are not going to work on a FWD car. So depending on what broke, you may be better fixing your trans, or trying to find another one.
justin the subie
not going to work what so ever? what are the details? ive got a rearend and axles wiring harness... maybe there is something im missing?
Wait....are you looking to do an AWD conversion? If so, then yes you can use the AWD transmission. You didn't elaborate you were planning on doing an AWD swap.
justin the subie
oh i see.. lol ive got everything to do the swap.. just dont know if the plugs on the trans wires are the same.. ive done a auto to manual swap before but not a 2wd Auto to 4wd Auto swap... hoping to find out all the details before i get too excited..
my best trans i have is the turbo Auto.. would that work or would i have to do a whole wire harness?
thanks for the help guys! :smt033
There should be no difference in electrical connector plugs between the FWD & AWD AT transmissions.
