Quick question. Is the ej25d pahase 1 fuel rails bigger than the 2.2 na rails?
Also on a related note. What's the injector size on a 98 2.5 legacy gt
fuel rails
fuel rails
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Re: fuel rails
I don't know the size of the rails, but the EJ25D injectors are tiny, in the range of 250-280cc.
Re: fuel rails
Plz define "bigger".__TT__ wrote:Quick question. Is the ej25d pahase 1 fuel rails bigger than the 2.2 na rails?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: fuel rails
More cc
Re: fuel rails
I've seen different reports on that. The '92-94 NA may be the same as the EJ25D. This POST shows them as the same.
And this LINK and this PIC (thanks to Legacy777 - again!) show that it may be true.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: fuel rails
I guess what im getting at is this. When doing the 98 dohc swap to my 22t. What rails and injectors should I use with the stock 22t ecu
Re: fuel rails
^The ones that match your ECU - the stock EJ22T. The rails will fit...or so I've been led to believe.
You can run the JDM, side-feed 440's, but it'll run rich and may idle poorly. That's about as big as you can go before the ECU can't handle them. I tried 480's and it ran, but poorly....although some say they work.
Highly recommend you look into the 'rob tuned' EJ20G ECU upgrade- Thread(s) on here. Rob can tune it for different setups/combos, incl. turbos, injectors, heads, etc.
TD
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
