»  BC-BF Legacy Discussion »  Turbo
#Cheap FCD
Custom Search
Login | Register
Post new topic Reply to topic  [ 158 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
Author Message
 Post subject: Re: Cheap FCD
PostPosted: Fri Jul 01, 2011 10:45 pm
Yeah, but probably not enough air to make much of a difference.
evolutionmovement wrote:
It was me. And those are my balls. Happy Sunday!
Profile  Offline
PostPosted: Tue Jul 26, 2011 11:21 pm
-Sorry for the bump, but i was wondering if there was any updates to anyone who has tried this? Is it still working, etc! I'm running a turbo xs dual stage boost controller, currently at 13lbs in 5th gear. I want to run 16lbs of boost.
-Reading thru this thread, it seems like an economical way of getting rid of fuel cut, but I'm still a little skeptic as i dont want to hurt or break anything.
-Joe
Profile  Offline
PostPosted: Wed Jul 27, 2011 1:42 am
These work from what I've read from others. It should be fine as long as you don't up the boost too much.
1997 Impreza OBS
Profile  Offline
PostPosted: Wed Jul 27, 2011 2:05 am
-Well all i'm looking for is 2-3 more pounds of boost. As i've heard the td04 is efficient up to 16lbs.
-It would be nice to see a DIY write-up on this but i'll go back thru and read it again to make sure i get things right.
-Joe
Profile  Offline
PostPosted: Wed Jul 27, 2011 11:48 pm
-So here's my setup. I went to Harbor Freight and picked up these items:
-1 #68198 1/4 x1/4 male-male coupler
-1 #68220 air inline regulator
-2 #68209 air brush adapter
-From auto zone I picked up:
-1 #47311 3/16" vacuum restrictor
-1 #47149 vacuum check valve (not used yet)
-My current setup:
-Parts:
-After assembly:
-The final product:
-I'm going to test this right now and let you guys know how it went. Let me know if I did something wrong and or what needs to be changed!
-Joe
Profile  Offline
PostPosted: Thu Jul 28, 2011 1:40 am
-So far so good, no fuel cut. But the real test for me is 5th gear on the freeway. AFR's still look good on the wideband, high 11's and low 12's.
-I'm going to be moving to San Bernardino CA. tomorrow so I'll post here what happens, if anything, once I get there.
-Joe
Profile  Offline
PostPosted: Thu Jul 28, 2011 6:12 pm
where'd you use the check valve?
Profile  Offline
PostPosted: Thu Jul 28, 2011 9:05 pm
I didn't use it. I got it just in case I needed it.
Joe
Profile  Offline
PostPosted: Fri Jul 29, 2011 1:13 am
so do u need an mbc to run this are do u not need one and also what is a good mbc that you can get with out ordering online like a napa are auto perfermace store
Profile  Offline
PostPosted: Fri Jul 29, 2011 6:05 pm
i don't think napa or an auto parts store would stock a MBC. there's a couple DIY threads on here about how to make one out of parts from home depot. Search home made manual boost controller or DIY manual boost controller.
Profile  Offline
PostPosted: Sat Jul 30, 2011 3:24 am
To up your boost past the stock boost lvl you will need a MBC, but you will only need the FCD if you are going past 13PSI i think
Tune
TMIC
Fuel
Taillight
n2x4 wrote:
Seriously, anything will fit. Subarus are LEGOs.
Profile  Offline
PostPosted: Sat Jul 30, 2011 3:36 am
Yeah, stock is at 13psi
Profile  Offline
PostPosted: Sat Jul 30, 2011 3:50 am
I thought stock was something like 8.7 PSI...
Profile  Offline
PostPosted: Sat Jul 30, 2011 4:03 am
stock boost is at 8.7, but fuel cut is at 13psi
Profile  Offline
PostPosted: Sat Jul 30, 2011 4:05 am
Caveman, you should paint the yellow caps the same red you painted your other accents. I think it will look real nice!
Profile  Offline
PostPosted: Sat Jul 30, 2011 6:06 am
I just might have to do that!
Joe
Profile  Offline
PostPosted: Wed Nov 09, 2011 6:32 pm
ive been using the 2way check valve and boosting 15lbs with no problems yet!
93 touring wagon
Profile  Offline
PostPosted: Fri Nov 11, 2011 12:21 am
Could one not use a check valve (to allow vacuume to get to the FCD) in parallel with a MBC backed down so the FCD sees 10 PSI but you are boosting 15 PSI? The check valve would block the boost.
Retired US ARMY SIGNAL CORP
65 B-Cuda Formula S, 78 Dodge Little Red Express Truck, 08 Suzuki Burgman 650 Super Scooter, 94 Legacy Touring wagon.
Profile  Offline
PostPosted: Fri Nov 11, 2011 6:58 pm
I'm sure you could do something, but tuning and configuring them would be kind of difficult I think.
1997 Impreza OBS
Profile  Offline
PostPosted: Wed Jun 13, 2012 2:26 pm
Yeah but do you have any mods or did you just crank the boost up? Becareful not to blow your engine up. I'll be the first for ectra parts ;)
Profile  Offline
PostPosted: Sun Jul 01, 2012 4:47 am
Dumb question but how do u know if ur car is hitting fuel cut
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
Profile  Offline
PostPosted: Sun Jul 01, 2012 4:51 am
Trust me you will know. It's like hitting the rev limiter with a little more whiplash effect lol
Joe
Profile  Offline
PostPosted: Sun Jul 01, 2012 5:05 am
Ok so not like bucking or anything like that
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Profile  Offline
PostPosted: Mon Jul 02, 2012 4:28 pm
Yeah, it's like all the power is taken away. It's pretty noticable.
1997 Impreza OBS
Profile  Offline
PostPosted: Mon Jul 02, 2012 7:43 pm
hmm ever since I turned up the boosr to 11psi my turbo is takinf for ever to get power
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Profile  Offline
Who is online
Users browsing this forum: No registered users and 0 guests
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
