91 legacy ss 22t bottom end?
evergreen
Post by evergreen »
blew the crank bearing on my 91 legacy ss.. used bottom ends arent too easy to find for this model.. anybody have one, or are there any other bottomends that will bolt up without a substantial amount of modification?
evan_whitehead@yahoo.com
Re: 91 legacy ss 22t bottom end?
Welcome to the BBS.
Is the block itself shot, or just the crank/bearings? If the short block is ok, you can use a crank from a non-turbo ej22, they are identical. If the block is shot, there's people selling used short blocks. You can check out the parts shed forum.
