heater hoses, where do they go
reecers
Post by reecers »
as you can see I have no heater hoses, and I have no idea where the hoses would go if I did have them. I bought a Chilton manual and it was no help and I have been searching frantically for some info but have found nothing... the heater core doesn't seem to leak so I don't know what the deal was. I bought the car this way.
Supposedly has a JDM EJ20 in it from what the previous owner said. Any help is much appreciated
1991 subaru legacy turbo sedan
Re: heater hoses, where do they go
The heater hose connections should be at the back driver's side of the engine. One will come off of the coolant crossover pipe and the other will come up and under the head from the pump.
Here's the full factory manual for the Aust. Liberty. It should have info on the cooling system and hoses in section 2.
http://www.main.experiencetherave.com/s ... SM_-_FULL/
