Nico's 93 Legacy Turbo
Re: Nico's 93 Legacy Turbo
you have a link to the throttle body? might be interested in trying one of those.
NICO
Post by NICO »
^^ its a S90 throttle body
NICO
Post by NICO »
well guys a new project has been done !
my sti ej20k heads one of the ex valves quit and instead of buying over sized valves i just went and got a jdm ver8 motor. in the ver8 the valves are oem oversized so no point in doing all this work to ver4 sti heads.
so what we have now is the same ej22t block with new better flowing heads !! i also add 1300cc DW top feed injectors bosch 044, and the new style ver8 intake manifold.. i should be in the over 400whp range but thats soon to come dyno plot.
also coming is a Full Race twin scroll headers with the new CRAZY BorgWarner EFR Turbos
Drool.
NICO
Post by NICO »
^^ hehe
well i found one and cant wait to put it on!! the car is all most done and ready to rock and roll !! just need to add this and she is good to go.
was from a jdm ver7 s202 so the lines are cut like all the crap from japan scrappers have, but i have new lines and cooler coming in to take advantage of this masterpiece !!
Dominator
Post by Dominator »
That's OEM hotness.
NICO
Post by NICO »
yep just a perfect item it even has a built in thermostat
So that's a fitting to put between the block & oil filter so you can run lines to an external cooler.....or is this for a dry sump setup?
NICO
Post by NICO »
Legacy777 wrote:So that's a fitting to put between the block & oil filter so you can run lines to an external cooler.....or is this for a dry sump setup?
Yes that's for a oil cooler pics will be up and where I mounted it been so busy with work
93legacylsleeper
Post by 93legacylsleeper »
Very Nice. Glad I checked in on this thread. Always getting better...
NICO
Post by NICO »
well my oil cooler does not want to fit so no go with that lol, im useing it for my other project subaru.
also need a new ecu to run this new set up so i got a Vi-pec 044
prodrive grp N pipe
mann hummel provent 200
also got some whiteline 22mm sway bars all around
cooler
NICO
Post by NICO »
well got it all dialed in and its bad ass ! my aps sr56 is got no jam up top but soon for next summer twin scroll EFR
Wow you peak soo low. Crazy.
NICO
Post by NICO »
Is that bad ? Or good ? Also my avcs is not working right so it's off... But when it does work I will have crazy down low.. I can't wait for my twin scroll rotated turbo set
Haha I think I misread that the first time. I thought it was peaking at 3,750rpm. Nevermind.
Florin1
Post by Florin1 »
That thing must be a neck breaker! Lol. Congrats on the 400+ hp club.
Now post a video
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
NICO
Post by NICO »
^^ it sure is a fun car cant wait for the bigger turbo
also just had a little fender bender :( my bad first one out my hole driving carer !! i am ashamed but what can you do.
winter set up black bbs wheels and some pirelli winter 240 sottozero serie ii
sparco wheel :)
Dominator
Post by Dominator »
Wow, how did you get your passenger seat so far back. I see they are fixed buckets. Probably aftermarket rails too huh. I really need to get more legroom for my drivers seat. It's killing my knees not being able to extend my legs out some more.
Falken-18c
Post by Falken-18c »
how tall are u guys lol im 6ft and with seat all the way back no problem lol you guys like 6ft5 lol
NICO
Post by NICO »
Dominator wrote:Wow, how did you get your passenger seat so far back. I see they are fixed buckets. Probably aftermarket rails too huh. I really need to get more legroom for my drivers seat. It's killing my knees not being able to extend my legs out some more.
you should see how far my seat goes back !! its crazy !! my buddy is around 6'3 and he has so much room its crazy !
they are sparco rials sparco base for our cars the seats come with the side mounts factory. both seats go back that far !! i wanted floor mount pedles and a longer wheel so i can put the weight in the back more.
Those seats are sick! Trade for my 02 WRX front and rears plus $100? :)
Dominator
Post by Dominator »
^^ I bet you I can guess the answer to that question is gonna be No. :)
I'm gonna try to extent the stock seat rails when I get to it this summer. I've got a spare set to mess with.
jamal
Vendor
Vendor
Post by jamal »
that oil cooler adapter is awesome. I actually have a solidworks drawing I made of almost the same thing around somewhere because a standard sandwich block doesn't fit unless you space it down.
Dominator wrote:^^ I bet you I can guess the answer to that question is gonna be No. :)
Yeah. I just want my seat rails shorter height wise. If I put product in my hair it hits the ceiling. No homo. Stupid wrx seats got my head in the clouds. I need the extended roof like they have on the Alpine Sport wagons.
kimokalihi wrote:If I put product in my hair it hits the ceiling. No homo.
You called it "product", and put "No homo" in the same statement, that's an oxymoron. :lol:
