I have a 1994 Legacy SS rally car, running a 2.2L NA engine and the stock 3.9FD Turbo transmission with a rear mechanical LSD out of a 91 SS.
I bought a 1991 Legacy L that had a good 4.11 transmission in it, stripped down the car and sent it to the junkyard. However, I forgot to pull out the pedal assembly, clutch cable, etc. because I was under the impression I could swap over my hydraulic setup into the 4.11 with no issues like on newer transmissions. So when the time came to put in the 4.11 transmission and saw there was no boss for putting in the turbo clutch fork I was rather.... pissed. But probably should have done more research.
So! My question is now, can I still salvage this transmission and convert it to using the hydraulic clutch setup that I have in my rally car? The 3.9 FD is absolutely killing me on high speed straights and making my transmission a 3-speed trans rather than a good ole 4-5 speed rally transmission.
Also, I have 3 diffs. The mechanical LSD rear that is a 3.9. A 4.11 VLSD from an 01 RS, and the stock 4.11 Open diff from the parts car. Is it possible to swap the Mechanical LSD guts from the 3.9 into the 4.11 (either VLSD or the Open one) so that I can have a 4.11 Mechanical LSD? I absolutely love love LOVE the mechanical LSD over the open or VLSD (might as well be open) so ideally I would like to keep that, while running the 4.11 gearing.
Annnnnd Legacy experts engage!
