Will it fit?
- Spelling Nazi
Will it fit?
Will 17" wheels fit with stock diameter tires and a 2" drop?
Hmmm. . . well, if 215mm tires are used, there shouldn't be really any rubbing then. . . so long as the offset of the wheel is correct.
Kelly. . .. what year Legacy do you have? Because the stock diameter on Laurel's 91 wagon would be the equivalent to a 215/40-17. I'm guessing you've got a newer car with a larger stock setup, right?
I had minor rubbing issues with my 205/45/17 on 17x7.4 w/ 48mm offest and a 2.5-3" drop all around. After i rolled the rear fenders there are no issues at all whatsoever.
W/o rolling, the stock tires 185/70?/14 have no rubbing at all.
It seems that it is mostly trial and error, some suspensions, even the exact same stock one may have rubbing, or may not.
MK
MK
1992 BC672 AWD 5MT
