Coolant leak
Coolant leak
Seems like its the coolant hose directly under the turbo, where does this run so I can replace it? Also, i'm having issues w/ my green connectors. When i plug them in the car acts like i have both sets of diagnostic connectors plugged in at the same time... Who the hell hacked up this harness... Wtf
93 Winestone TW project
Re: Coolant leak
I don't know about the harness but the coolant hose are you referring to the one that connects and makes a U? it sits right above the midpipe?
Re: Coolant leak
The one directly below the turbo, the one that is a huge pita to attach
Re: Coolant leak
It goes from the turbo drain to the back of the passenger side head.
Re: Coolant leak
K thanks, and any idea about the weirdness with the green plugs? They turn the fans on and all the electronics click...
Re: Coolant leak
Here are some pics showing where it goes.
http://www.main.experiencetherave.com/s ... P_5953.JPG
http://www.main.experiencetherave.com/s ... P_5954.JPG
What you described about the green connectors is normal. They cause the ECU to go into diagnostic mode and it cycles all the relays so you can check if they're working or not.
Re: Coolant leak
I'm using my normal code reading method but i'm not getting any blinking lol
