Bypass the clutch damper with part numbers!
bmxkelowna
Post by bmxkelowna »
Just recently did a 5mt swap in my new turbo legacy, I've always preferred the feel of cable clutch trannies with push type pressure plates but I was able to get a full 91 turbo drive train from flywheel to lsd for 300$
I've been driving it for about a week now and HATE the feeling of the hydro/pull type so I figured I would start with removing the clutch damper.
I used
Russell pn: 656222 (20" straight -3 dot approved stainless line)
Russell pn: 641411 (-3 to 10x1 female fitting)
Russell pn: 640471 (-3 to banjo fitting)
My brother works at lordco so I paid 39$ after tax for everything.
The banjo attached to the clutch master, and the female fitting attached to the hard line that goes to the slave.
The 20" is a little long but lets you have lots of room to route the hose.
Outcome? 100% better, nice solid pedal feel from top to bottom and returns smoothly and quickly.
http://performanceparts.com/part/Russell/656222
http://performanceparts.com/part/Russell/641411
http://performanceparts.com/part/Russell/640471
Re: Bypass the clutch damper with part numbers!
Interesting. Never felt the clutch when it had the damper on it. I removed mine before I got the engine running. I didn't use any parts though. Just used the hose that went to the damper.
bmxkelowna
i didnt even think to check if it was long enough, figured the braided line would be the best (stiffest) option other then hardline.
Oh yeah. If I recall correctly it wasn't actually long enough but with a slight bending of the hard line I was able to connect the two easily.
Yeah, I did not use the damper at all and am very happy with the hydro feel.
Deride
Post by Deride »
Yea was much better without the damper, especially when bleeding it.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
CFK
Post by CFK »
Man I wish I read these threads before purchasing 2 SS lines, installing it with a new slave. Such a B!tch to
bleed :!:
Got a 15" line, guess i'll remove that POS Damper and try, try again :!: :smt013
I Now hate Hydraulic clutches and Power Steering, really miss my bare bones MK1 Jetta more & more, just not the NA FWD
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
