»  BC-BF Legacy Discussion »  Body, Chassis and Interior
#Odometer question
Custom Search
Login | Register
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Odometer question
PostPosted: Fri Oct 24, 2014 1:43 am
As i previously stated in another thread which i still dont know how to link in. My wifes cars gauge cluster shit the
bed. I went to the junk yard this moring and pulled a new cluster out of another car with 20k less miles.
Now this might be a long shot but can i just turn the little cable connection in the back to increase the mileage on
the cluster i bought?
1993 legacy ss "Shela"
Profile  Offline
 Post subject: Re: Odometer question
PostPosted: Fri Oct 24, 2014 1:54 am
Yes, you turn the cable in the back and it will increase the mileage. However, you'll be there for quite some time to add 20k miles.
What year did you grab the new cluster out of and what year is your wife's SS? Assuming they're similar years, I'd just swap the rear plastic piece with the electrical connections. That would be the easiest thing to do.
1997 Impreza OBS
Profile  Offline
PostPosted: Fri Oct 24, 2014 2:00 am
My wifes car is a 93 and the one i got it from was a 94, i didnt know i could do that. Im assuming just do it super careful as to not damage the ribbons
Profile  Offline
PostPosted: Fri Oct 24, 2014 2:09 am
Yup, the 93 & 94 should be the same. Yes, just be careful with removing the bulbs and screws and transferring the ribbon over to the original cluster.
1997 Impreza OBS
Profile  Offline
PostPosted: Fri Oct 24, 2014 2:12 am
there seems to be a giant capacitor attached to the ribbon, im hoping this isnt wired to anyting else inside the cluster?
Profile  Offline
PostPosted: Sun Oct 26, 2014 10:53 pm
That is the seat belt chime. It should swap over.
1997 Impreza OBS
Profile  Offline
PostPosted: Wed Jan 04, 2017 2:49 pm
So THAT is where the annoying seat belt chime is...thats enough to make me pull the cluster if that is what has to happen to disable it. Can anyone verify that is what must happen?
Profile  Offline
PostPosted: Wed Jan 04, 2017 7:03 pm
Are you wanting to get rid of the chime because of the key in the ignition or from the seat belts?
If it's from the key in the ignition you can disconnect the plug/wire from the key cylinder assembly that triggers the chime. If it's from the seat belts, you might have to get creative at the seat belt computer or pull the wire going to the chime at the cluster.
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 0 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
