SOLD 1990-1995 EJ22E Delta Camshafts - 220 'Torque' Grind
wtdash
Post by wtdash »
SOLD
Two Cams - driver and passenger side SOHC- from a '90-'95 EJ22e w/the HLA/flat tappet NON-roller rocker valve assembly. Will NOT work w/the roller rockers in the '96+ heads.
BUT if you use the HLA/Flat tappet valve assembly they CAN be used in the '96-'98 EJ22E heads, based on what I read HERE on the USMB.
I had these installed for about one month and decided the uneven idle wasn't worth it....I do a lot of stop and go on my commute and I have an Automatic.
I DID feel an improvement in power based on the butt-dyno.
And these will fit the EJ22T heads as that how I used them (I'm running EJ22T heads as NA/Non-turbo).
These are $167 + shipping and core charge if bought new.
Asking $140 SHIPPED.
Cams rolled over 180°.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: FS: 1990-1995 EJ22E Delta Camshafts - 220 'Torque' Grind
Post by SILINC3R »
Pictures no working
I see em
93Leg-c
Post by 93Leg-c »
No worky for me, too.
'94 TW
wtdash
Post by wtdash »
Hm. Linked to pics on Nasioc. http://forums.nasioc.com/forums/showthr ... ?t=2757812
I'll fix later
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
wtdash
Post by wtdash »
bumping up
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
