Entire 96 wrx driveline cost
SomeOldHobo
Post by SomeOldHobo »
Im trying to get the engine, tranny, rear diff, driveshaft, control arms, ecu, wiring harness, with only 88xxx kms on it seller wants 4500. does that sound like a bit much?
Re: Entire 96 wrx driveline cost
On ebay the ej20g engine and transmission with ecu usually go for $1500 shipped or plus shipping. Sure you don't get the rear diff, driveshaft, control arms, and wiring harness, but do you really need all those for an additional $3k?
The driveshaft won't work for a legacy, the control arms on the wrx are the same thing (STI's could have aluminum control arms, but those go for around $250), and the legacy wiring harness only needs minor wiring to accept the ej20g engine and ecu...
SomeOldHobo
mike-tracy wrote:On ebay the ej20g engine and transmission with ecu usually go for $1500 shipped or plus shipping. Sure you don't get the rear diff, driveshaft, control arms, and wiring harness, but do you really need all those for an additional $3k?
Thank you sir
