Ej23
94LegacyT
Ej23
Post by 94LegacyT »
Does anyone know if you can swap a ej20. Into an Ej22 car? The ej20 is a dual can where my Ej22 is not
Sent from my E6782 using Tapatalk
Re: Ej23
There's a lot of info about this in the engine section of the forum. Check out the stickies.
Sent from my SM-N920T using Tapatalk
94LegacyT
Re: Ej23
Post by 94LegacyT »
I don't have time to read I have 10 minutes until I can get this or I'm out
Re: Ej23
Fine. Yes you can.
94LegacyT
Re: Ej23
Post by 94LegacyT »
Little little effort like drop straight in or do I gotta mess with it
Re: Ej23
There will be a decent amount of work involved.
I don't know what ej22 you have, because you didn't list what car you have. I don't know what ej20 you're looking at because you also didn't list which one you were looking at.
94LegacyT
Re: Ej23
Post by 94LegacyT »
I have a 94 legacy turbo. This motor is a 93 dohc twin turbo motor?
Re: Ej23
It can work with some modifications to misc exhaust and intake configurations.
94LegacyT
Re: Ej23
Post by 94LegacyT »
Okay thank you!
94LegacyT
Re: Ej23
Post by 94LegacyT »
Would I be able to slap my 22turbo intake and exhaust on it and just run it without twin turbo?
Re: Ej23
Hi, spend some time in here: http://bbs.legacycentral.org/viewtopic.php?t=38247 It covers DOHC head swap and complete dohc engine swap, from the mechanical side.
If you have a left hand drive, the exhaust from the twin turbo will interfere with your steering column. If you have a right hand drive, no fitment issue. You'll need a twin turbo crossmember, or custom up pipes made regardless.
If you want to run any engine as a single turbo, you can get away with just swapping in a turbo crossmember, and the up and down pipe will fit, or have custom pipes made. There is no exhausts that fit the 1st gen legacy, except for those that are made for it specifically. Any exhaust you find can be made to work by a welder, time and money.
A phase 1 SOHC intake manifold (1990-1998) will not fit phase 1 dohc heads (1989-1998) heads. Nor will any other year sohc intake on phase 1 dohc heads..
The wiring is another story. Any turbo swap will involve ton of wiring.
94LegacyT
Re: Ej23
Post by 94LegacyT »
I already have a turbo motor. I have a 94 legacy turbo ej22t. I found a low like ej20 I want to just make it a single turbo
Re: Ej23
There ya go then.
Re: Ej23
mike-tracy wrote:There ya go then.
Yep.
94LegacyT
Re: Ej23
Post by 94LegacyT »
So it should work without having to swap computers?
Re: Ej23
Not swapping computers? I wouldn't bother. It wouldn't be any better than what you have now. But would have less torque.
You really got to do some searching on this.
Re: Ej23
I did briefly run a full ej20g (same thing as ej20H but single turbo) off the stock 22t electronics. Only change I made was add an intercooler.
94LegacyT
Re: Ej23
Post by 94LegacyT »
It ran good boost wise and all?
94LegacyT
Re: Ej23
Post by 94LegacyT »
Yea I have a 22 turbo non intercooled.
Re: Ej23
It ran exactly the same as the 22t, just less torque. Maybe a teensy bit more top end. But like I said, it's a waste of time, because the 2.0L dohc motors really shine with a bigger turbos and proper tuning (or even a normal ej20g ecu).
IMO, you'll get a lot more for your money by keeping your stock engine and getting a robtune from robtune.com (and upgrading your turbo, injectors and adding an intercooler). That's what I ended up doing - went back to a 22t and did the mentioned upgrades.
94LegacyT
Re: Ej23
Post by 94LegacyT »
I never had an original engine. That's why I'm asking. When I bought the car it has a N/A motor with a turbo slapped on it
94LegacyT
Re: Ej23
Post by 94LegacyT »
But you're saying the 20 will run on the 22 ecu?
Re: Ej23
It has been done many many times.
Re: Ej23
Which 22 ecu?
I ran my ej20g engine on my 22t ecu (my car is a factory turbo). I put the ej22t pink injectors on so it didn't run super rich.
94LegacyT
Re: Ej23
Post by 94LegacyT »
Thanks everyone!!
