Warm starting problem
Andrewc_21
Post by Andrewc_21 » Sun Jun 18, 2017 2:41 am
So for a few weeks now I have been having this warm starting problem with my 93 N/A wagon, when I start it in the morning it starts right up, same if it is hot and I try starting it within a few minutes of turning it off. However, when it is hot, sits for 25-30+ minutes, it cranks for about 4-5 seconds before firing up. I have done hours of research and replaced:
the coil pack
plugs and plug wires
coolant temp sensor
PCV valve
Battery
fuel filter
fuel pressure regulator
cam position sensor
crank position sensor
... And I still have the exact same problem. I can hear the fuel pump prime when I turn it to ON and once it starts it runs smooth, never misfired or stalled on me, if anyone has any suggestions they would be much appreciated!
Andrewc_21
Re: Warm starting problem
Post by Andrewc_21 » Tue Jun 20, 2017 6:11 am
Add to that list the injectors and rails, and I cleaned the IACV with throttle body cleaner, still starting hard when it's warm I am 100% stumped
Post by Legacy777 » Mon Jun 26, 2017 5:32 pm
Have you put a fuel pressure gauge on the fuel line to see what it's doing while starting?
Do you have a spare MAF you can try? I don't know if I'd recommend buying a new one at this point, but could be worth swapping as a troubleshooting exercise.
1997 Impreza OBS
Andrewc_21
Post by Andrewc_21 » Mon Jun 26, 2017 11:36 pm
Hey, I actually (knock on wood) just resolved the issue, replaced the fuel pump and strainer and so far has been starting as it should at all temps, thanks though!
Post by Legacy777 » Tue Jun 27, 2017 5:49 pm
Good to hear the problem is fixed.
1997 Impreza OBS
