»  BC-BF Legacy Discussion »  Intercooling
#tmic vac line
Custom Search
Login | Register
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: tmic vac line
PostPosted: Tue Sep 26, 2017 10:38 pm
So how do you guys route your vac lines with a TMIC. I have a 91 ss that did not come with a TMIC and the person i bought the car from installed one and some of the vac hoses are not routed right. Some are kinked. Other note the car has a wrx 2.0 block with 22t heads. So the vac port up front is not there.
The TMIC is off a 06 wrx I think.
1991 subaru legacy sport sedan
Profile  Offline
 Post subject: Re: tmic vac line
PostPosted: Fri Nov 03, 2017 5:43 pm
Are you referring to the crankcase vent lines?
If so, most people figure out whatever way they can route them. However, it's important to keep the modified routing functioning the same as the stock setup.
1997 Impreza OBS
Profile  Offline
PostPosted: Sat Nov 04, 2017 12:09 pm
Just out of curiosity, do you have a pic of the car?
There's a vacuum reference diagram on the bottom of the hood. If you follow that and make sure everything is hooked up accordingly, you'll have better peace of mind.
Profile  Offline
PostPosted: Wed Nov 08, 2017 5:43 pm
i will get photos tonight
Profile  Offline
PostPosted: Thu Nov 09, 2017 4:56 am
Profile  Offline
PostPosted: Thu Nov 09, 2017 4:58 am
This mess. Kinked hoses... missing parts?
Profile  Offline
PostPosted: Thu Nov 09, 2017 5:23 am
The long out of production factory hoses had nice molded bends in em. I've used those plastic 90* elbows and a T in the appropriate sizes, from autozone.
Profile  Offline
PostPosted: Thu Nov 09, 2017 1:47 pm
You'll have to use a different photo sharing site. We cant see anything from photobucket.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 3 guests
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
